car idles at 2k
Old Mar 25, 2003 | 01:48 PM
HaUTSaauce's Avatar
New User
Default car idles at 2k FITV?
car idles between 1800 and 2000 rpms and surges
HELP!!
i covered up the bottom hole in the throttle body and the car idles smooth
i need to get this fixed
[Modified by HaUTSaauce, 2:50 PM 3/26/2003]
Old Mar 25, 2003 | 04:13 PM
HaUTSaauce's Avatar
New User
Default Re: car idles at 2k (HaUTSaauce)
anyone?
Old Mar 25, 2003 | 04:43 PM
greebler's Avatar
bottom hole? ummm take a picture for me... How did this hole come to be?
Old Mar 25, 2003 | 05:16 PM
boosted hybrid's Avatar
Its a vacuum leak. Once you get it fixed, your idle will return to normal.
Old Mar 25, 2003 | 07:51 PM
99silverbullet's Avatar
Default Re: car idles at 2k (boosted hybrid)
it could be the iac valve, same thing was happening to my car. hth
Old Mar 25, 2003 | 08:09 PM
kwil666's Avatar
Default Re: car idles at 2k (99silverbullet)
i had that problem on my car changed the IAV didnt work did the same test you did by covering the hole your talking about and that test if for the FITV (i think its called). its on the bottom of the TP.
keith
Old Mar 26, 2003 | 12:49 PM
HaUTSaauce's Avatar
New User
Default Re: car idles at 2k (kwil666)
is there any way to fix the FITV? i took it apart and screw the white piece back in and i still get the same idle problem
Old Mar 26, 2003 | 02:56 PM
HaUTSaauce's Avatar
New User
Old Mar 27, 2003 | 04:13 AM
HaUTSaauce's Avatar
New User
Default Re: car idles at 2k FITV? (HaUTSaauce)
bump
Old Mar 27, 2003 | 04:25 AM
(teh)H2OUUP2's Avatar
you probably have the port open on the bottle of your throttle body. I believe that it is the coolant bypass, there sould be a valve attachement that bolts to that that covers the vacuum port. Did you recently put on a ported throttle body?
Old Mar 27, 2003 | 12:22 PM
HaUTSaauce's Avatar
New User
Default Re: car idles at 2k FITV? (JDMSir-G)
no the TB is not ported and i dont see any ports open, i sprayed carb cleaner in the TB and intake manifold area and there were no signs of a vaccum leak
Pat_Black
Dec 4, 2013 02:06 PM
STUCKED
Mar 1, 2005 12:52 PM
DrewDown
Jan 1, 2005 03:45 PM
GOTNOS
Nov 22, 2004 01:33 PM
Convoy
Feb 12, 2004 08:13 AM
