oversize bore & piston?
Old Mar 26, 2003 | 09:13 AM
B pwr's Avatar
Default oversize bore & piston?
b18c1
finishing my block, just need pistons.
i know post to be bore the block to the pistons spec, but got ahold of block - no pistons, previous owner had it bored & honed 50 over for 81.5mm piston that supposedly - it had, took it to machine shop, actually bored 40 over(.016in).
my question what piston size would i need for that bore?
seems like honda oversize piston, not sure.
ok, any help/posts or recommendations/ suggestions welcome
thanx
Old Mar 26, 2003 | 09:52 AM
19924ws's Avatar
Default Re: oversize bore & piston? (crxpwr)
Use mine for an example H23A1. Stock bore was 87mm. A .020 over piston comes out to 87.5mm. You can check http://www.jepistons.com to see what size you need even if they are not je pistons
Old Mar 26, 2003 | 10:13 AM
B pwr's Avatar
Default Re: oversize bore & piston? (19924ws)
ok, i will take a look at that.
thanx
Old Mar 26, 2003 | 10:44 AM
brainwo's Avatar
New User
Honda Oversize only go up to .25 anything after that, you need aftermarket or resleeves.
But check with portflow then have ITR .50 oversize piston w/ring.
xjdmjunkiex
Feb 28, 2011 08:26 PM
user 98292739
Aug 15, 2009 07:26 PM
Yambor
Apr 29, 2005 10:55 PM
swlabhot
Jun 1, 2004 10:56 AM
turboex
Mar 1, 2004 11:11 AM
