Koni Shock Height Adjustment Clip
Old Mar 27, 2003 | 08:03 PM
xtal's Avatar
Default Koni Shock Height Adjustment Clip
How durable are those clips? After being used for awhile, to adjust the height, should they be replaced? I can't see any easy way to retighten them as they don't appear to be standard C-clips with holes to remove/install.
Old Mar 29, 2003 | 11:26 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Koni Shock Height Adjustment Clip (xtal)
You should find a height that suits you, then leave it alone. Alignment settings change (toe and camber) when the ride height changes, so it would be in your best interest to get the car aligned after you have found a setting you like. I haven't changed mine in over a year, with no signs of any problems.
TOO MUCH TORQUE
Suspension & Brakes
Mar 5, 2014 08:09 AM
da9pwnsu
Apr 24, 2006 09:17 AM
kevinoneill
May 13, 2004 05:11 PM
WhiteTeg2000
Feb 4, 2003 03:07 PM
taytay333
Mar 25, 2002 09:07 PM
