Need CTR valve lash ASAP
Old Mar 25, 2003 | 02:52 PM
MisterB's Avatar
Default Need CTR valve lash ASAP
i need the valve lash for ctr. just finished the swap and adjusted the valves and still ticking... it is for a b16a with ctr pistons,cams,springs, and retainers... thanks
Old Mar 25, 2003 | 03:15 PM
advanracing62's Avatar
Default Re: Need CTR valve lash ASAP (cl4show)
I think all honda VTEC lash is the same... .007
Old Mar 26, 2003 | 11:17 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Need CTR valve lash ASAP (advanracing62)
actually arent they 0.006 and 0.008?
intake 0.20mm
and exh 0.25mm?
Old Mar 26, 2003 | 12:12 PM
Default Re: Need CTR valve lash ASAP (boostedcivicsir)
I think the intakes are .006 and the exhaust are .008 but you can run .007 on both and be perfectly ok. It's easy to remember and allows a slight bit of leway, as they are both +/- .002
Old Mar 27, 2003 | 09:23 PM
MisterB's Avatar
i did 6 and 8 seems to be fine the clicking seems to be coming from the bottom end but i just had it rebuilt, bearings, seals, etc. it also smokes every once and a while... is this normal will it stop once it is broken in?
Old Mar 27, 2003 | 09:48 PM
MikeSarr_GSR's Avatar
.17-19mm intake / 25.4 = .0067"- .0075"
.19-21mm exhaust / 25.4 = .0075" - .0083"
hope you get that bearing knock worked out. did you recently install cams? if you dont get the cam cap specs right sometimes they will knock a bit 18-20ft-lbs on the 12mms and 6-8ft-lbs on the 10mms
does it knock until heated up? is it a a knock knock knock or a knicka-knicka
if it is fast it is in the block due to 2 rotations of the crank to one of a cam.
If it is slower, chances are it is in the head. Been there dude... hope you get it sorted out
[Modified by MikeSarr_GSR, 6:55 AM 3/28/2003]
Kr4nG
Nov 17, 2009 03:33 PM
Serdar
Mar 25, 2007 04:20 AM
kirby_lys
Feb 3, 2007 12:33 PM
markaria
Sep 27, 2001 08:37 AM
