New Overheating Problem :*(.............again but opposite
Old Mar 26, 2003 | 02:18 PM
intekragsr's Avatar
Default New Overheating Problem :*(.............again but opposite
Ok, I used to overheat at idle. I swapped in a fluidyne radiator, oem thermostat and thermoswitch and cometic headgasket. This fixed the idle overheating issues.
BUT.............
Now I am having overheating problems when driving The needle seems to jump real high really fast, then right when i turn the heater on full blast, it drops a tiny bit and then rises back up for a while.
After driving like this for 10 minutes on the highway, i finally got home, idled and the temperatre didnt move Could it possibly be a bad temp gauge? How would I check that and do those go bad often?
I checked the coolant and notcied a tiny bit of flaky white stuff sitting at the top of the radiator. What is it? junk from the new radiator?
[Modified by intekragsr, 11:19 PM 3/26/2003]
Old Mar 26, 2003 | 02:33 PM
intekragsr's Avatar
Default Re: New Overheating Problem :*(.............again but opposite (intekragsr)
update, i just found a bunch of crusty white mushy crap under my new radiator cap..........wtf is this?
Old Mar 26, 2003 | 02:47 PM
B16Ej1's Avatar
what kind of "cosmetic" headgasket did you purchase???, the answer may lay in that right there....
my bad, i thought you said "cosmetic head gasket",
[Modified by cream, 11:48 PM 3/26/2003]
Old Mar 26, 2003 | 02:48 PM
B16Ej1's Avatar
Old Mar 26, 2003 | 02:49 PM
intekragsr's Avatar
Default Re: New Overheating Problem :*(.............again but opposite (cream)
i have a .043 cometic headgakset
just did compression check:
1 - 190
2 - 181
3 - 190
4 - 195
[Modified by intekragsr, 12:00 AM 3/27/2003]
Old Mar 26, 2003 | 03:35 PM
intekragsr's Avatar
please help
Old Apr 29, 2003 | 01:32 PM
B18EG6's Avatar
what mix of coolant are you running? are your head studs torqued down correctly?
^ problems i encountered
Old Apr 29, 2003 | 01:46 PM
intekragsr's Avatar
Default Re: New Overheating Problem :*(.............again but opposite (B18EG6)
haha how did this thread come back alive?
This problem was on my old motor.
Now I have a new motor, making different problems.
Let it die.....
gvinson89
Jun 24, 2012 07:03 PM
thakidd
May 15, 2008 01:45 PM
jseames
Aug 22, 2003 12:38 PM
intekragsr
Mar 27, 2003 11:23 AM
intekragsr
Mar 26, 2003 04:15 PM
