piston and rod sizing?
Old Oct 1, 2003 | 08:55 PM
integra6650's Avatar
Default piston and rod sizing?
Deck hight 211.5mm
Bore 84.5mm
what size pistons and rods would i need.
Old Oct 1, 2003 | 10:48 PM
TimoneX's Avatar
New User
Default Re: piston and rod sizing? (integra6650)
Why 211.5 and not 212mm? Which crank?
Old Oct 5, 2003 | 07:53 PM
Default Re: piston and rod sizing? (TimoneX)
Dart Block Gsr Stock crank
Old Oct 5, 2003 | 08:48 PM
TimoneX's Avatar
New User
I think they only make 212 & 226mm blocks. The 212mm block would use stock 137.9mm rods with a GSR crank.
Old Oct 6, 2003 | 06:45 AM
http://www.windsorhonda.net/dart.html
and all others say 211.5 so would i just have to take .5 off your Number im not too familiar with sizing yet just started stripping down motors
Old Oct 6, 2003 | 11:49 AM
TimoneX's Avatar
New User
The B18a/b/c B16b B20b/z are all 212.0138mm. Perhaps dart made them slightly shorter to increase compression who knows. In theory the rods used with a GSR crank should be .25mm shorter with that block, but I bet you get away with using stock length GSR rods(137.9) and then if necessary a slightly thicker gasket.
On a side note...$3300!?! for a block? screw that. You could get a stock one and sleeve it to 86mm for half that.
Old Oct 6, 2003 | 01:49 PM
1800
Old Oct 6, 2003 | 02:59 PM
mmuller's Avatar
Mad Scientist
stock height rods will work, pistons...well you already know.
what crank?b18b crank=b18b rods
vtec crank=vtec rods
Old Oct 7, 2003 | 09:17 PM
Default Re: piston and rod sizing? (mmuller)
and just get wider pistons for the 84.5 mm bore
Old Oct 7, 2003 | 09:34 PM
TimoneX's Avatar
New User
I'd probably bore to 85mm, but you can get either size from several manufactures. I'm running shelf JE 85mm pistons currently. Very nice design.
Old Oct 8, 2003 | 04:06 PM
you sayin have the dart block bored to 85
Old Oct 8, 2003 | 10:26 PM
TimoneX's Avatar
New User
Sure why not. It'll bring displacement to 1979cc.
Old Oct 9, 2003 | 07:18 AM
sweet thanks
Leric
11
Aug 9, 2013 06:45 PM
TimKennard
Apr 27, 2013 12:15 PM
JeremyL
Dec 6, 2002 01:45 PM
Civicdrgrcr
Sep 9, 2002 08:17 PM
boosted hybrid
Sep 8, 2002 02:18 PM
