ecu codes
Old Oct 5, 2003 | 11:34 AM
redcivicek's Avatar
Default ecu codes
i have the following codes on my car 14 (idle air control),22(vtec oil pressure switch),3(manifold absolute pressure),4(crankshaft positon),7 (throttle position circuit). i need need to know how to check and fix all of these problems.
Old Oct 5, 2003 | 03:49 PM
FlatLineEG8's Avatar
Default Re: ecu codes (redcivicek)
you check all the connectors? the Vtec Preasure switch is the green connector right behind the Vtec Solenoid. the other sensors are on your throttle body and intake manifold, make sure all the connectors match up, and you didnt accidently put the wrong harness on the wrong sensor, its possible.
JDMmadness
Nov 7, 2010 05:50 PM
Fairburn
16
Sep 16, 2009 04:36 PM
trickedyfz450
Apr 15, 2006 12:32 PM
b16a_ef9
May 4, 2005 04:11 PM
