torque specs for 2piece rotor?
Old Oct 5, 2003 | 10:24 AM
euclid's Avatar
Default torque specs for 2piece rotor?
does anyone know what i should torque the bolts to on a 2piece rotor, aluminum hats? thanks
Old Oct 5, 2003 | 11:43 AM
Kamin's Avatar
Default Re: torque specs for 2piece rotor? (euclid)
the screws or your wheel lugs?
the lugs go to stock torque and the screws don do anything. i usually dont even reinstall them when i do brakes. they just hold the rotor to the hub while you put the wheel on. the lugs do all the work once its driving.
Old Oct 5, 2003 | 01:24 PM
euclid's Avatar
Default Re: torque specs for 2piece rotor? (Kamin)
no, the specs on the bolts for the rotor that connect the aluminum hats to the friction surface. they are 2piece and i am worried if i under-tighten they will rattle loose, if i i overtourque they may warp... i searched google with no good results.
Old Oct 5, 2003 | 01:29 PM
Kamin's Avatar
ohhhhh
contact the manufacturer of the rotor, i dont wanna give out the incorrect specs.
Old Oct 5, 2003 | 02:00 PM
euclid's Avatar
yeah i will tomorrow but it is sunday, i was hoping to get it finished this weekend and it completely slipped my mind till today.
B_Swapped93
Suspension & Brakes
Oct 10, 2018 02:25 PM
eddiebuiltEK.
Jan 30, 2009 10:07 AM
Ductologist
Sep 5, 2004 09:41 AM
Seks
Feb 25, 2003 02:31 PM
