B16A2 crank angle sensor??
Old Oct 4, 2003 | 08:58 PM
mastarolla's Avatar
Default B16A2 crank angle sensor??
i just bought the b16 block and the previous owner had removed the CA sensor and said it wouldnt make a difference on performance...is this true or a bunch of BS?
Old Oct 7, 2003 | 09:25 PM
salbaje's Avatar
Default Re: B16A2 crank angle sensor?? (mastarolla)
yes it wont matter depending on which ecu you are using.
Old Oct 8, 2003 | 08:30 PM
deepgreengsr's Avatar
Default Re: B16A2 crank angle sensor?? (salbaje)
if you run obd2 you will throw a code which wont send the ecu into limp mode. but I reccomend converting it back. It should only cost under 100$ for the crank pulley and the sensor.
goldfinger93030
Jun 1, 2010 09:55 AM
CHAZegHATCH
Jul 20, 2006 06:33 PM
TheOwnrOfTheEk9
Mar 7, 2006 06:10 PM
