stupid ABS
Old Oct 4, 2003 | 01:49 PM
social_control's Avatar
Default stupid ABS
im sure everyone on here knows about that annoying sound that the abs pump can make? well if you do, please help me solve this problem...when i start my car up, it makes an "erggggkkkjel;kjga" sound...very loudly and annoyingly...and sometimes when im driving i hear it to...wtf? could somebody please explain to me what is going on and how i can fix this w/out spending too much money....thanks in advance....-scott
Old Oct 4, 2003 | 04:27 PM
Chiovnidca's Avatar
Default Re: stupid ABS (Seprioth64)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Seprioth64 &raquo;</TD></TR><TR><TD CLASS="quote">im sure everyone on here knows about that annoying sound that the abs pump can make? well if you do, please help me solve this problem...when i start my car up, it makes an "erggggkkkjel;kjga" sound...very loudly and annoyingly...and sometimes when im driving i hear it to...wtf? could somebody please explain to me what is going on and how i can fix this w/out spending too much money....thanks in advance....-scott</TD></TR></TABLE>
It's building presure. If it's working good and not throwing any codes, I would leave it be. Some are louder than others.
Old Oct 4, 2003 | 08:57 PM
Default Re: stupid ABS (Chiovnidca)
bump
Old Oct 4, 2003 | 11:07 PM
HONDADNA's Avatar
When you first the start you car the ABS pumps operates to build up pressure in the accumilator. However, you mentioned that you also hear pump running while driving - that is normal.
Most Honda's leaks brake fluids at the accumilator and they don't set codes. This is for the older Acura legends, 90-93 integra's and some of the later Accords. In fact, Honda had a Service Bulletin on ABS pump running with no codes.
Any ways, local the ABS accumilator and look if you see any brake fluid leaks. Also, on most Honda's you will feel and excessive brake pedal effort. Most of the customer I've dealt with discribes it a soft brake pedal.
Hope that was some help..
Old Oct 5, 2003 | 05:26 AM
Default Re: stupid ABS (HONDADNA)
what can i do to stop this? VERY LIMITED BUDGET
Old Oct 5, 2003 | 07:43 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Seprioth64 &raquo;</TD></TR><TR><TD CLASS="quote">what can i do to stop this? VERY LIMITED BUDGET</TD></TR></TABLE>
You can try bleeding the fluid.
Old Oct 5, 2003 | 06:27 PM
bump...any more suggestions...ill bleed the system thru the caliper sometime this week when school lightens up
Old Oct 5, 2003 | 08:00 PM
HONDADNA's Avatar
What vehicle do you have? So, I can tell which system and type of ABS unit you. If you have a 94 - 96, it's a tpye 2 ABS system and they are command to leak between the ABS mod and accumilator. And, the fix is replacing a o-ring and it cost about $5-$10.
But on good thing is, you don't need a special tool to do this. All you need a 10mm wrench and common hand tools.
Old Oct 6, 2003 | 08:05 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Seprioth64 &raquo;</TD></TR><TR><TD CLASS="quote">bump...any more suggestions...ill bleed the system thru the caliper sometime this week when school lightens up</TD></TR></TABLE>
Bleeding the regular brake system isn't going to do anything. Try bleeding the ABS modulator.
Old Oct 6, 2003 | 08:08 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDADNA &raquo;</TD></TR><TR><TD CLASS="quote">
But on good thing is, you don't need a special tool to do this. All you need a 10mm wrench and common hand tools.</TD></TR></TABLE>
It's much more common for the modulator plugs to leak than the accumulator o-ring. They also trigger the ABS light when the fluid gets low.
Old Oct 6, 2003 | 09:54 AM
timmy8151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
It's much more common for the modulator plugs to leak than the accumulator o-ring. They also trigger the ABS light when the fluid gets low.</TD></TR></TABLE>
I agree with Chiovnidca.
If you hear your accumulator pressuring up for a while, then you probably need to change the O-ring. Contact BSQ on this board. He did a good writeup on how to change the seal.
Old Oct 6, 2003 | 10:28 AM
Default Re: stupid ABS (timmy8151)
ill do the o-ring first, then see about the modulator plugs...where in the system is this ring placed (pictures would be cool) and could someone describe to me how to do this or link to a previously explained thread...BSQ? is this his full name? thanks for the help!
Old Oct 6, 2003 | 10:42 AM
timmy8151's Avatar
PM BSQ
https://honda-tech.com/zero...=1048
nm_Civic_DrVr
Honda Civic (2006 - 2015)
Dec 27, 2006 09:51 AM
PhantesS
Honda Civic (2001 - 2005)
11
Sep 13, 2006 06:48 PM
hndarcrb18c1
Oct 20, 2003 04:07 AM
social_control
Oct 16, 2003 09:30 PM
social_control
Oct 15, 2003 07:40 PM
