Bent valves: going SKUNK2 valvetrain
Old Oct 2, 2003 | 10:57 AM
hatchattak's Avatar
Default Bent valves: going SKUNK2 valvetrain
I have a 99 B18B
ok let's just say my valves are bent, rough idle i think i hear clicking (still need to do compression and leakdown...can someone tell me how to do it?).
im thinking of going skunk2 valvetrain except cams.(going drag genIII later), will i have to do anything else to the head other than internals? will i have any problems staying with my stock LS cams? is it pretty much plug and play as far as putting in new valvetrain components then putting back on the head?
Old Oct 2, 2003 | 02:47 PM
junya16's Avatar
Default Re: Bent valves: going SKUNK2 valvetrain (hatchattak)
i'd check to make sure your valves are bent before i'd upgrade my entire valve train...and if you're gonna redo the valve train you may as well do the cams at the same time...not worth the hassle of pullin the head off twice...and nothin in the head has to do w/ plug and play
Old Oct 2, 2003 | 05:54 PM
tilt's Avatar
Default Re: Bent valves: going SKUNK2 valvetrain (junya16)
you can swap the cams w/o taking the head off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junya16 &raquo;</TD></TR><TR><TD CLASS="quote">i'd check to make sure your valves are bent before i'd upgrade my entire valve train...and if you're gonna redo the valve train you may as well do the cams at the same time...not worth the hassle of pullin the head off twice...and nothin in the head has to do w/ plug and play </TD></TR></TABLE>
Old Oct 2, 2003 | 11:20 PM
junya16's Avatar
Default Re: Bent valves: going SKUNK2 valvetrain (tilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt &raquo;</TD></TR><TR><TD CLASS="quote">you can swap the cams w/o taking the head off.
sorry the head off once and the valve cover off once...guess i should be a little more specific next time...
Civic-eg
12
Jun 21, 2013 02:20 AM
S13 slide
Mar 24, 2006 02:25 PM
Acoupdetat
Aug 27, 2004 05:44 AM
goforbroke
Nov 20, 2003 05:30 PM
speedracer9k
Oct 13, 2003 06:32 AM
