torque specs for cam caps and plates???
Old Oct 5, 2003 | 05:56 PM
dabomb's Avatar
Default torque specs for cam caps and plates???
i cant find my manuals anywhere and i need these torque values for the cam caps, plates, and for the cam pulley bolts. the motor is a b18c1. thanks
Old Oct 5, 2003 | 06:08 PM
mts20k97's Avatar
Default Re: torque specs for cam caps and plates??? (dabomb)
the 14mm bolts are 20 ft/lbs and the 10mm are 7.2. not sure about the pulley bolts but i think its around 37.
Old Oct 5, 2003 | 06:24 PM
Mochanic's Avatar
Default Re: torque specs for cam caps and plates??? (mscivic12)
12mm, not 14mm...
Old Oct 5, 2003 | 06:26 PM
TREVER's Avatar
Default Re: torque specs for cam caps and plates??? (Mochanic)
actually there 8 and 6 mm you measure the threads width not the head
Old Oct 5, 2003 | 06:33 PM
dabomb's Avatar
so everybody pretty much agree's on those numbers, now if i can only get the torque value for the cam pulley's
thanks for help guys
Old Oct 5, 2003 | 06:42 PM
Mochanic's Avatar
yes, but while some people know this, most people that can't tell by looking at the bolt what size it is find it much easier to go by what socket fits the bolt heads. Eitherway, we know what bolts he's talking about.
Yes, 7.2 and 20 are correct.
Old Oct 5, 2003 | 07:05 PM
IN VTEC's Avatar
41lb*ft for the 14mm cam gear bolts. Everything else is fine.
EK FLY
Jun 5, 2005 08:04 PM
tehBullet
Apr 5, 2005 06:59 PM
FitCRX
Feb 5, 2003 11:47 PM
