coil-over spring rates
Old Oct 1, 2003 | 08:00 AM
dose's Avatar
Default coil-over spring rates
i got some tokico blues for my ek and plan on getting some ground control coil-overs,i kno i need atleast teg spring rates cause of the b18 but i was wondering what would be the pros and cons of getting the spring rates stiffer and how much should i go cause i want the ride to be stiffer
Old Oct 1, 2003 | 08:09 AM
azian21485's Avatar
Default Re: coil-over spring rates (dose)
practically all aftermarket springs will have a higher springrate than factory...pros and cons depend only depend on how much comfortable ride quality your willing to sacrafice...most spring rates can range from anywhere to 150 - 400 ...
pro: better handling
con: feel bumps
note that you need good shocks to accomidate higher spring rates
Old Oct 1, 2003 | 12:12 PM
dose's Avatar
so what are standard spring rates for integras and what would be a good setting for stiffer springs on a street car,feeling the bumps dont bother me imused to lowered trucks
Old Oct 1, 2003 | 01:41 PM
azian21485's Avatar
iunno the exact rates for stock but its fairly low...there is no real good setting..its all preference..and how stiff u set your shocks also..but if u really must noe some numbers..i have kyb agx shocks and hnr sport springs...but i can't remember their spring rates rite now...i think around 150ish?
boyong07
Suspension & Brakes
Mar 17, 2008 03:51 PM
ITRtist
Suspension & Brakes
13
Apr 14, 2007 08:19 AM
Team Bukkake Sucks!!!
Jun 13, 2006 09:28 AM
DrewQ1
Aug 10, 2004 08:01 AM
.Ryan
Aug 18, 2002 04:47 PM
