redone head on old block.
Old Oct 1, 2003 | 09:31 AM
Space Boy's Avatar
Default redone head on old block.
I am just posting this for my buddy to what what everone has to say about this.
My friend has an integra se(ls) and the engine has 50,000km on it with no internal mods. He is thinking of purchasing a B18a head off my buddy that has been port polished and getting 403 cams with springs in it. The head is milled 20 thousand. He was wondering if he puts the head on his engine if it will seal properly(with new gaskets of coarse). His logic comes from the fact that the engine has some km's on it and if it would have warped a bit with the head. If he puts the new head on will the block have a slight warp to it or should it still be straight. He doesn't want to take the block out to have it decked.
Old Oct 1, 2003 | 09:57 AM
Muckman's Avatar
Moderator in Chief
Default Re: redone head on old block. (Space Boy)
Im not an engine builder but I have swapped heads between engines before and never had any problems with head gasket seal from the deck or head being warped. I dont believe it should be warped from just normal use, unless the engine had overheated at some point.
Old Oct 1, 2003 | 10:12 AM
mmuller's Avatar
Mad Scientist
Default Re: redone head on old block. (Muckman)
as sayd above, you should be ok meng
Old Oct 1, 2003 | 10:49 AM
19924ws's Avatar
Unless he over heated then there should be no prob. He can always check it himself with a feeler gauge and a straight edge. The specs and tolerances are in the service manuel.
bretberger
Honda Civic (2001 - 2005)
Jan 8, 2018 08:23 PM
nintu
Jul 21, 2013 07:56 PM
journeyquest
Jul 12, 2011 02:56 AM
90ZCREX
Jun 3, 2011 10:07 PM
af97civic
Jun 6, 2003 06:48 PM
