Clutch slave cylinder
Old Oct 5, 2003 | 05:58 PM
denshu's Avatar
Default Clutch slave cylinder
hey all
just need a little help here, my slave cylinder is squeeking like crazy everytime
i push in the cluch and then release. it's probley time to replace it.
i have a 94 civic with a y21 tranny. can i just use the stock cx slave cylinder that orginally came with the car?
some help would be nice
thanks alot
Old Oct 5, 2003 | 06:05 PM
TommyV's Avatar
Default Re: Clutch slave cylinder (denshu)
Slave cylinders are indentical CX,DX,LX,EX,SI,VX..... (92-95 anyways)
Are you sure your slave cylinder is squeeking? For me it was my clutch pressure plate......
I'd only replace it if it was leaking.. mine was, so I replaced it.
Old Oct 5, 2003 | 06:40 PM
denshu's Avatar
Default Re: Clutch slave cylinder (TommyV)
well i installed a new exedy clutch and pressure plate already a month ago, so i knoe it's not that..
and the squeeky sounds came from where the slave cylinder is so for sure it's that.
i tired lubbing it with some lith. grease and it still made noise. the boots all riped and stuff..so i probley need to change it...
so the stock cx slave cylinder would fit to my b16's tranny?
thanks for the reply
Old Oct 5, 2003 | 11:51 PM
ill phil's Avatar
Yeah, it should be the same boot. Are you sure it isn't the fork or bearing in the tranny casing right there?
Old Oct 6, 2003 | 12:52 AM
tegasaurus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by denshu &raquo;</TD></TR><TR><TD CLASS="quote">well i installed a new exedy clutch and pressure plate already a month ago, so i knoe it's not that..
thanks for the reply</TD></TR></TABLE>
if you jsut replaced the clutch, and now your slave cylinder is conveniently squeeking, it sounds like the PP to me... my friends does that often, the throw out bearing will rub against the pp and make a squeek/screeth noise as you're releasing it.
-ryan
Old Oct 6, 2003 | 06:27 PM
denshu's Avatar
Default Re: Clutch slave cylinder (tegasaurus)
Hmmm so does this mean i have to crack open the tranny case again?
if it was the fork, would it do any damage if i leave it squeeking?
it engages fine...it's just so annoying!!
Old Oct 6, 2003 | 07:49 PM
jaysonx's Avatar
Put some grease where the slave cylinder contacts the release fork. I did have this problem once upon a time as well, and it was the pressure plate (as mentioned before).
Mugen112
Jul 16, 2009 07:14 PM
jaywo_23
Oct 11, 2007 08:49 PM
tbonez
Jun 12, 2005 05:27 PM
B18PoweredCivic
Sep 24, 2003 10:58 AM
integls95
Jan 1, 2003 09:25 PM
