Is it okay to install springs without a spring compressor?
Old Oct 5, 2003 | 11:09 AM
Kirei's Avatar
Default Is it okay to install springs without a spring compressor?
My friend said he would do it for me since he's done it to his car before and he said its okay without a spring compressor. All the spring compressor does is make it easier for the entire process to fit the spring in right?
Old Oct 5, 2003 | 11:16 AM
mmuller's Avatar
Mad Scientist
Default Re: Is it okay to install springs without a spring compressor? (Kirei)
you can say it helps...you wont be able to put it in without one
Old Oct 5, 2003 | 11:32 AM
LudeyKrus's Avatar
Default Re: Is it okay to install springs without a spring compressor? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">you can say it helps...you wont be able to put it in without one</TD></TR></TABLE>
Doing it w/o a spring compressor is not an option.
Old Oct 5, 2003 | 11:34 AM
Kamin's Avatar
Default Re: Is it okay to install springs without a spring compressor? (LudeyKrus)
haha actually ive done springs without a compressor. had 2 people push down on the spring just enough to thread the bolt on.
anyway get a compressor tho. you can rent them from autozone/checker.
Old Oct 5, 2003 | 11:59 AM
ill phil's Avatar
Default Re: Is it okay to install springs without a spring compressor? (Kamin)
If you are a DIY'er, I'm sure you could make a spring compressor. But like Kamin said- just go rent one from Auto-Zone.
Old Oct 5, 2003 | 05:11 PM
Timmy!'s Avatar
Use your feet and aim it into the bucket. Its a piece piece of cake.
Tim
Old Oct 5, 2003 | 05:38 PM
fox297's Avatar
Some aftermarket springs don't need a compressor. I've done mine (g2 teg) and my friend's rsx without the compressor.
Old Oct 5, 2003 | 06:02 PM
VTECorona's Avatar
Default Re: Is it okay to install springs without a spring compressor? (fox297)
Aftermarket springs are smaller than stock ones. You will just need a compressor to disassemble the stock unit to get the top mount off if you need to reuse it.
Old Oct 5, 2003 | 06:06 PM
mts20k97's Avatar
I've never used a spring compressor. just an impact to get the nuts on the strut loose.
Old Oct 5, 2003 | 06:09 PM
v4lu3s's Avatar
RTFM
i raely use a srping compressor
i often lossen the nuts on the shaft while the car is on teh ground and then put the new spring on and let the weight of the car compress the spring.
Old Oct 5, 2003 | 06:55 PM
dunkd's Avatar
yup, never had to use one. just pop the top bolt off and aim the spring away from you and watch it pop off!
as far as putting it back together you won't need a spring compressor b/c ur lowering spring isn't as long as stock... therefor it wont have to be compressed.
Old Oct 5, 2003 | 07:23 PM
ross1459's Avatar
Default Re: (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">yup, never had to use one. just pop the top bolt off and aim the spring away from you and watch it pop off!
as far as putting it back together you won't need a spring compressor b/c ur lowering spring isn't as long as stock... therefor it wont have to be compressed.</TD></TR></TABLE>
yup. just catch the nut in a towel or something
Old Oct 5, 2003 | 08:30 PM
DropSquadCivic's Avatar
Default Re: (ross1459)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ross1459 &raquo;</TD></TR><TR><TD CLASS="quote">
yup. just catch the nut in a towel or something </TD></TR></TABLE>
hehe nut in the towel.....
all you need is a impact gun and a 14mm.
jrivehard
Suspension & Brakes
22
Dec 16, 2008 09:26 PM
HondamanXxX
19
Jun 21, 2007 04:30 PM
sleeping_forest
10
Nov 11, 2002 08:07 PM
itr157
Feb 25, 2002 04:55 PM
tjtruong
Nov 27, 2001 09:30 PM
