Help me figure out what is wrong.
Old Oct 1, 2003 | 04:44 PM
flat-blk-HB's Avatar
Default Help me figure out what is wrong.
Ok I just swapped in my LS vtec into my 92 civic HB CX..It came out of my 88 DX HB..I converted to OBD1 via dizzy and injectors...p72
set-up..B18A block..B16A1 head and intake..Hyrdo to cable set-up for tranny..P72
yes the knock sensor is hooked up and.
Here is the problem..
While driving at a constant speed between 2-3.5K rpm the car will chug, if you know what I mean? It will pop sounding come from the exhaust and not pull then out of no where it will pull then start feeling like it is missing again. Here is what I have done..
Change Plugs and Wires..(old used wires)
The TPS voltage is .59 which I beileve is too high?
I dont know what to do I am lost and getting tired of messing with it..Any help is greatly appericated..
Old Oct 1, 2003 | 06:36 PM
mmuller's Avatar
Mad Scientist
Default Re: Help me figure out what is wrong. (flat-blk-HB)
i would adjust the tps first to see wha happens(.45 to 4.5), are you using a p72 ecu?
Old Oct 1, 2003 | 06:39 PM
Default Re: Help me figure out what is wrong. (mmuller)
yeah bro I am going to mess with the TPS tomorrow. I am using a OBD1 P72. I have the Knock sensor wired to D3 and it is not throwing a code.
Old Oct 1, 2003 | 06:41 PM
mmuller's Avatar
Mad Scientist
do that cause it sounds like a tps problem
Old Oct 1, 2003 | 06:48 PM
ghettochild's Avatar
has your tps ever been fucked with
Old Oct 2, 2003 | 04:11 AM
Default Re: Help me figure out what is wrong. (ghettochild)
yeah actually it has. It is a JDM TB so the adjusting screws are torq's and it looks as if it has been moved before. And also I did not remember this til last night but most of the sensor case is cracked..The part the wire goes on..Could it be fucked up and not throw a code?
Hanmin
18
Sep 25, 2021 09:21 PM
rollinhonda3
Jun 19, 2011 02:55 PM
Black_Rex
Jan 23, 2006 03:27 PM
Jimmy L
Apr 17, 2003 10:58 AM
