Wierd thrust washer problem....
Old Oct 3, 2003 | 07:37 AM
Benny Hinn's Avatar
Default Wierd thrust washer problem....
I have an engine(B18A) that has eaten a set of thrust washers once. I pulled the bottom end apart and replaced the crank as well as installed new thrust washers. The endplay was measured, and was within spec. The engine still makes the same "ticking/crunching" noise as before. All of the bearings are perfect, so I know that the noise isn't any type of knock.
The complete bottom end has been checked and reassembled, but the noise continues. I am about to pull it apart again to check the thrust washers. Any ideas on what would cause an engine to eat the thrust washers?
Old Oct 4, 2003 | 06:35 AM
Benny Hinn's Avatar
Default Re: Wierd thrust washer problem.... (Benny Hinn)
anyone?
Old Jan 10, 2005 | 08:00 AM
MyVtec8yourV8's Avatar
BUMP!!!! im having the same problem with my h22 thrust washers.. but its a tck not a crunch
blue89hatch
Mar 30, 2007 10:17 PM
ScorpioX
Jul 17, 2005 08:29 PM
adrianw
Sep 28, 2004 04:25 PM
adrianw
Nov 19, 2003 09:35 AM
