cutting bumpstops
Old Oct 3, 2003 | 01:14 PM
LillDragun's Avatar
Default cutting bumpstops
how did you cut your bumpstop?? what did you use to cut it? did you need a vise or anything?
Old Oct 3, 2003 | 01:33 PM
pro1342's Avatar
Default Re: cutting bumpstops (LillDragun)
Cut in half with a razor blade....
Old Oct 3, 2003 | 01:47 PM
spaceman's Avatar
bumpstops on your shocks?..i took mine completely out..hehe..works for me
Old Oct 3, 2003 | 01:49 PM
pro1342's Avatar
Default Re: cutting bumpstops (spaceman)
That works too, but it's a pretty hard hit if the suspension bottoms out.
Old Oct 3, 2003 | 03:00 PM
mathusala's Avatar
Default Re: cutting bumpstops (pro1342)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pro1342 &raquo;</TD></TR><TR><TD CLASS="quote">That works too, but it's a pretty hard hit if the suspension bottoms out.</TD></TR></TABLE>
maybe he took the bumpstops and the springs out...
Old Oct 3, 2003 | 03:29 PM
sikcrx80's Avatar
use the bump stops cut in half could save sturts
Old Oct 3, 2003 | 04:17 PM
LillDragun's Avatar
Default Re: (sikcrx80)
so just a razor? it isn't tough to cut is it?
Old Oct 3, 2003 | 04:48 PM
Lysawy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pro1342 &raquo;</TD></TR><TR><TD CLASS="quote">Cut in half with a razor blade....</TD></TR></TABLE>
Old Oct 3, 2003 | 04:59 PM
mathusala's Avatar
Default Re: (LillDragun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LillDragun &raquo;</TD></TR><TR><TD CLASS="quote">so just a razor? it isn't tough to cut is it?</TD></TR></TABLE>
a little more difficult than cutting a styrofoam cup. just be patient w/razor blade...
Old Oct 3, 2003 | 05:59 PM
RPRacing's Avatar
do you have to cut them at all???
Old Oct 3, 2003 | 07:22 PM
-Trinitron-'s Avatar
You dont have to cut them at all unless you go below 2". Although I cut like the first two ribs off to drop mine 1.5-1.75. You can cut them with a sharp pocket knife or a razor. A heavy duty box cutter would be ideal. Don't cut your arm off!
Old Oct 3, 2003 | 07:43 PM
LillDragun's Avatar
welli didn't realize i need to cut them off untill after the installation and i saw the instructions for the springs and they said to trip off 30 mm.
Old Oct 4, 2003 | 01:28 PM
LillDragun's Avatar
damn that was easy!!!.....the hardest part was getting my shock/spring assembly off the car.....i used a onesided razor and like ya'll said.....it's just a lill tougher than a styrofoam cup!
TheTealHatch
Welding / Fabrication
11
Jun 16, 2007 02:52 PM
Skapeoner
Nov 14, 2006 10:56 AM
PINKS
Suspension & Brakes
Jan 12, 2006 12:59 AM
Immanuel
Dec 26, 2005 12:11 PM
