Catless Integras - resistor mod to avoid CEL? (what ohm?)
Old Oct 4, 2003 | 04:24 PM
JustChou's Avatar
Default Catless Integras - resistor mod to avoid CEL? (what ohm?)
Hello all-
I'm currently helping my boss Ed move his Integra GSR from SSB to ITS, and one of the mods he's incorporating is a straight pipe. However, in order to avoid a CEL, I believe we need to modify the signal of the 2nd (the later) O2 sensor. Does anyone know what resistor to use for this application?
Thanks in advance.
Old Oct 5, 2003 | 03:26 PM
JustChou's Avatar
Default Re: Catless Integras - resistor mod to avoid CEL? (JustChou)
bump for a great road racer
Old Oct 5, 2003 | 05:44 PM
fox297's Avatar
Just a thought. Couldn't you just tap the second wire into the 1st sensor.
Old Oct 5, 2003 | 07:08 PM
JustChou's Avatar
Default Re: Catless Integras - resistor mod to avoid CEL? (fox297)
I believe the two readings must be different otherwise OBD-II figures out that there's no "catalizying" going on between the two sensors.
Old Oct 6, 2003 | 04:20 PM
JustChou's Avatar
C'mon, someone has to have some knowledge of this.
Old Oct 6, 2003 | 04:37 PM
Padawan's Avatar
Darth ModerVader
Since it's a race car, why not just pull the CEL bulb or cover it up?
Old Oct 6, 2003 | 04:49 PM
turbotypeR@SPEC's Avatar
25 Year Member
try tying it up under the car still plugged in but not in the pipe.
Old Oct 6, 2003 | 08:14 PM
JustChou's Avatar
Default Re: Catless Integras - resistor mod to avoid CEL? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Since it's a race car, why not just pull the CEL bulb or cover it up?</TD></TR></TABLE>
Just in case there's a more important problem the ECU picks up?
Old Oct 6, 2003 | 08:19 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustChou &raquo;</TD></TR><TR><TD CLASS="quote">Just in case there's a more important problem the ECU picks up?</TD></TR></TABLE>
Yes, that's a good point. Have you looked into any of the commercially available O2 sims?
D17alltheway
Honda Civic (2001 - 2005)
Jan 4, 2008 09:54 AM
Ghetto Civic HX
Dec 19, 2007 10:17 AM
solerizr
Feb 25, 2007 10:15 AM
luiggie
Feb 21, 2004 08:07 PM
ActiveAero
Jun 16, 2002 06:24 PM
