question about timing???
Old Oct 3, 2003 | 10:50 AM
cliff666's Avatar
Default question about timing???
i recently set my timing back to stock and i did everything correctly when adjusting the distributor timing. but after my battery died (left headlights on ) i went to the track and the car just seemed like it was lagging up top so i checked it again this time it was 4-6 degrees advanced!!! hwo in the hell did this happen???? if anyone can tell me i would appreciate it alot thanks
cliff
Old Oct 3, 2003 | 10:59 AM
mmuller's Avatar
Mad Scientist
Default Re: question about timing??? (dragboy)
did you bypass the service connector when you adjusted it?
Old Oct 3, 2003 | 12:15 PM
cliff666's Avatar
Default Re: question about timing??? (mmuller)
yea and i just checked it again and now it is again 2 degrees retarded now....WTF!!!!! anyone can help me out ???
Old Oct 4, 2003 | 06:10 PM
cliff666's Avatar
when i bypass it the car seems to run slower my best run of the day was a 14.8@93 on friday night and i adjusted it without jumping the plug and the timing didnt move until later today when i checked it at the track. some one must kno whats going on. i would think its maybe just me but when u look at my slips u could see a difference after the 1/8 mile. someone tell me whats up.
Old Oct 7, 2003 | 10:42 AM
Happyman's Avatar
bump help this fella out
Old Oct 7, 2003 | 11:18 AM
Okley_01's Avatar
Well, the only thing I can think of is if its something simple like not having the distributor tightened down all the way. Or if you have some kind of after-market timing management that is not functioning properly.
Old Oct 7, 2003 | 01:30 PM
TeStUdO's Avatar
Default Re: question about timing??? (Okley_01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Okley_01 &raquo;</TD></TR><TR><TD CLASS="quote">Well, the only thing I can think of is if its something simple like not having the distributor tightened down all the way. Or if you have some kind of after-market timing management that is not functioning properly.</TD></TR></TABLE>
Yeah are you sure you tightened the bolts down correcty?? Also maybe try changing the bolts maybe the threads are stretched somehow
Old Oct 8, 2003 | 04:02 PM
jaader's Avatar
Ok I have a question. Exactly how do you set the ecu in bypass mode while adjusting the timing?
I am working on a 99 civic.
93lsv_turbo
Apr 15, 2011 12:08 PM
darkd1gt
Nov 21, 2005 08:45 PM
MugenGTR
Nov 14, 2002 05:03 PM
98slvrcx
Jul 28, 2002 09:58 PM
