B16a swap: code 3
Old Jul 25, 2013 | 12:37 PM
Canadian_EF's Avatar
Default B16a swap: code 3
Alright so I swapped in this b16, fully rebuilt to OE specs. Timing is set, valves adjusted, fluids added, ECU is a p28 with phearable basemap, ecu is known to be good and working. I pressurized the crankcase and started it up for the first time. Started no problem. Throwing code 3 however. It runs a little rough.
Code 3 is map sensor, so I replaced it with a known good one. Reset the ecu and tried again. Code 3 again. Checked my vacuum lines, seemed good, so I replaced the line just in case and used a T to tap into the vacuum for the FPR. Same code. There's no vacuum leak, putting my hand over the throttle shuts the motor off.
I had to extend my map sensor wiring, I am most certain I put it back in the right order.
Short of testing my whole harness, what else could this be, other than a wiring fault?
Nathan_volcom
Dec 4, 2011 03:01 PM
hecubus
Feb 26, 2007 03:07 PM
ViXoN Hatch94
Apr 17, 2006 07:11 PM
Nextelbuddy
10
Jun 19, 2005 07:24 AM
DAMCOOLDAV
Sep 28, 2003 11:34 AM
