Prepping headgasket mating surface
Old Jul 15, 2013 | 08:50 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Prepping headgasket mating surface
I pulled the head off my car to replace the head gasket. Took the head to the machine shop where they milled the gasket surface of the head. Do I need to wipe down that fresh surface on the head with alcohol or acetone or anything else? What about the surface of the block?
Old Jul 15, 2013 | 08:53 PM
v8killaz's Avatar
Default Re: Prepping headgasket mating surface
has to be clean from old material and oils. if its brand new from the machine shop slap it on
Old Jul 15, 2013 | 09:27 PM
Community Builder
Oh okay, wasn't sure seems like there might be a little residue from the machining process left on the head.
Old Jul 15, 2013 | 10:20 PM
Community Builder
How do I clean this stuff off the top of the piston walls? Razor scraper got some but not all of it.
Old Jul 15, 2013 | 10:51 PM
v8killaz's Avatar
i would use a bristle disc/pad on that. dont use a razor blade though it will gouge that aluminum. ive used razor on d-series motors that use the composite gaskets since they seal pretty good but the steel ones need a clean and smooth surface. subaru guys use a big sanding block but ive never done it that way.
obviously best way is let a machine shop touch it up slightly so it matches nicely with the freshly surfaced head
Old Jul 16, 2013 | 03:15 AM
Shmallow's Avatar
i've had success starting with carb/TB cleaner or similar and letting it remove what it can chemically. give it a few rounds of that followed by shop rag wipe down. if there are any stubborn areas left i hit them by hand with some scotch-brite.
wiping with a clean rag soaked in brake pars cleaner is a good final prep for mating surfaces before assembly.
Old Jul 16, 2013 | 05:08 AM
Community Builder
I was very careful with the razor scraper to not gouge anything, but since the possibility is there for damage I guess I won't use it anymore.
Cool I have both carb and brake cleaners in the garage. When you say Scotch-Brite you're referring to those scrubber sponge pads right?
Old Jul 16, 2013 | 08:50 AM
Shmallow's Avatar
right, kind of. kitchen spounges come with a scotch-brite pad glued to one side for scrubbing. S-B pads without the spounge are what i was refering to.
something like this something like this
. a box like that lasts a very long time in my garage.
Old Jul 16, 2013 | 10:01 AM
Community Builder
lol dang I swear Amazon has freakin' everything
KidRuthless
Dec 3, 2013 08:58 PM
mehrshadvr4
Aug 3, 2009 05:06 PM
sickerhatch
Mar 25, 2005 10:54 PM
3rdGteg
Oct 5, 2003 09:27 PM
rasta420
May 21, 2003 08:15 PM
