2003 Accord Ex
Old Jul 22, 2013 | 07:24 AM
Dan Brewer's Avatar
Default 2003 Accord Ex
Engine stalls with either turn signal on or if the brake pedal is pressed.. I think that I am either looking for a possible alternator or battery problem or perhaps the mult-function switch that controls the headlights/dimmer/turn signals may be bad. Can the multi function switch be replaced by removing the steering column covers ? Or, does the steering wheel and air bag have to be removed .
Old Jul 22, 2013 | 08:55 AM
averyvm's Avatar
Default Re: 2003 Accord Ex
What happens when you turn on the headlights?
Old Jul 22, 2013 | 10:03 AM
Dan Brewer's Avatar
Head lights do not matter on or off , just turn signals or brakes
Old Jul 22, 2013 | 12:27 PM
BOXER247's Avatar
Try checking the coils
Old Jul 22, 2013 | 03:56 PM
Dan Brewer's Avatar
ignition coils ?
Old Aug 2, 2013 | 05:16 PM
Dan Brewer's Avatar
Replaced combo switch ( headlights / dimmer /turn signal ). Looked like the old one was dripping oily junk... charged battery at 15 amp to full . Turned charger on 2 amp and it alternated between low and 50 % all afternoon. Had battery tested and they made 2 attempts and said that battery would not test. Replaced battery. Completed this Tuesday afternoon and my daughter has not alerted me to any problems since then,. I held on to the original "combo switch"...If enough people complain about this problem, there would be recall as it is a safety hazard for the engine to die when using brake lights or turn signals. It had a p 0685 fault code...Ecm/Pcm malfunction code., apparently set by the combo switch..... Just because you get a code like that does not mean that the ecm /pcm needs replacement... It could mean as in this case, that there is something else that effects/affects the ecm/pcm that sets the code. Local dealer quoted the switch @ about $38.00 but would have to be special ordered and payed for in advance. I pre-ordered the switch for $47.00 and took it with me from Jasper, AL to Lexington,Ky. Daughter bought the battery locally , probably $100 to $ 115.00 .... and then there is a matter of a 825 mile round trip road call....and about 24 hours from start to back home . Honda America says that they have never heard of this problem. I am not happy !
Misty Taylor
Honda Civic (2001 - 2005)
Aug 28, 2019 11:38 AM
turboteg90
Nov 15, 2009 05:26 PM
nedjinski
Sep 7, 2007 03:04 PM
ekntra
Aug 24, 2005 07:44 PM
Tx92AccordExD
Jul 22, 2003 03:52 PM
