Cleaning the PCV Valve without removal?
Old Jul 23, 2013 | 11:22 PM
TheIVJac|{al's Avatar
Default Cleaning the PCV Valve without removal?
I have a GSR and everything I've read says that it's really hard to get to the valve to remove. I was wondering, is it possible to remove the other end of the tube and spray WD-40 in there to improve the performance of the valve? As in, you disconnect the tube from the crankcase, spray WD-40 down into the tube, leave the tube up high so that the penetrant reaches the valve, thus cleaning the PCV. What do you think, would it work?
- Aaron
Old Jul 24, 2013 | 09:36 AM
Cynical 1's Avatar
Default Re: Cleaning the PCV Valve without removal?
just change it.
no quick fix to clean it - all the junk would go into the black box or the crankcase.
they are under $15 new from a parts store, and take about 30 mins to maneuver in there... if you have the stock intake.
Old Jul 25, 2013 | 12:59 PM
Anyone else? Thoughts?
Old Jul 27, 2013 | 04:55 AM
94EG8's Avatar
Seagull Management
They're hard enough to clean properly off the car so no. Replace the valve.
jasoncrashtech
May 25, 2013 08:10 PM
jmdinn
Nov 4, 2012 07:41 PM
vinuneuro
May 21, 2006 12:03 PM
b16bhatch
Nov 18, 2005 12:16 PM
petrv
Aug 26, 2005 02:26 PM
