o2 Sensor
Old Aug 8, 2013 | 02:58 PM
sully3275's Avatar
Default o2 Sensor
07 Civic Si, my o2 sensor reads low voltage and I was curious to if moving the secondary o2 sensor back further from its primary position (due to a longer flex pipe) will it cause this reading?
Old Aug 8, 2013 | 06:29 PM
m90polk1's Avatar
Default Re: o2 Sensor
It shouldn't matter the secondary o2 is only used to monitor emmissions and is only looking for catalytic converter efficiency .....any voltage drop would be internal to the sensor itself nothing you can control
Old Aug 8, 2013 | 06:32 PM
doood's Avatar
been there done that
did you delete the cat?
Old Aug 8, 2013 | 08:53 PM
silkypillows's Avatar
extending an o2 sensor with too long of a piece of wire, or splicing in a heavier gauge wire will cause voltage drop, and potentially an o2 low voltage code.
creuger
Nov 15, 2002 07:11 PM
