Clutch pedal problems! Video inside!
Old Aug 7, 2013 | 11:01 AM
DingDang's Avatar
Default Clutch pedal problems! Video inside!
So my clutch pedal is not fully coming all the way up after I step on it. I now have a little hard time getting out of first and into the other gears because of this and it's making me look really bad. I was told it might be a master cylinder/slave cylinder. I can drive the car fine but it makes me look like its my first time driving it... Releasing the clutch too quick...
Here's a video.
If it is the master cylinder problem does anyone have a link for me to fix it?
If the link doesn't work let me know. Working on my ipad.
Old Aug 7, 2013 | 11:43 AM
lsturbo33's Avatar
Default Re: Clutch pedal problems! Video inside!
Most likely master/slave. Check the system for a leak. What kind of car is it and the year model?
Old Aug 7, 2013 | 12:23 PM
DingDang's Avatar
Oh sorry it's a 1996 gsr integra
Old Aug 7, 2013 | 12:24 PM
DingDang's Avatar
Yeah my buddies are telling me its that too.
Old Aug 7, 2013 | 01:56 PM
lsturbo33's Avatar
The master cylinder usually leaks up by the clutch pedal under the dash. The slave cylinder is mounted on the front of the transmission and you can check it for leaks also. You can try to bleed the system but if it just happened out of no where most likely a leak. Check to see if the the brake fluid in the reservoir is low. It's the small reservoir in the driver side of the engine bay.
Old Aug 7, 2013 | 09:31 PM
DingDang's Avatar
Yeah thanks guys I just went out and bought a new slave and master cylinder. Going to replace it tomorrow. But I've been asking around and yeah i feel like it is the master and slave. It did just happen out of nowhere. I think I need those cylinder covers. The basketball wristbands? Lol
Old Aug 7, 2013 | 09:33 PM
DingDang's Avatar
It didn't feel like the clutch cylinder was losing any fluid though. I think.... I did bleed it but it only worked for it a bit and than it went back to being stupid. Ha
zach1288
Jan 21, 2010 03:16 PM
crxricer66
Dec 1, 2007 07:58 PM
FuNkDrSpOt
Oct 10, 2006 09:48 PM
siregcivic
Oct 16, 2005 07:55 PM
ATS*Mark
Aug 23, 2005 09:55 AM
