A/C: desiccant replacement
Old Aug 4, 2013 | 01:34 PM
Tiger_Fit2007's Avatar
Default A/C: desiccant replacement
I have a 2007 Honda Fit that I replaced the A/C compressor recently. I pulled the condenser to replace the desiccant sleeve but Im having trouble figuring out how to remove the end piece (aluminum). I removed the c-clip but unsure as to the next step, any help would be GREATLY appreciated.
Thanks!
Old Aug 4, 2013 | 06:30 PM
Default Re: A/C: desiccant replacement
Got it. You can pressurize the condenser and force it out or you can use the internal threads to pull it. Then you can change the desiccant bag. Very quick process...
Farquea
Apr 17, 2018 12:03 PM
B_Swapped93
Dec 6, 2013 06:30 PM
Charliegrs
Nov 27, 2006 11:11 AM
Wet Nudl
Apr 30, 2002 07:17 PM
