B16 in EG swap help ( wiring )
Old Jul 23, 2013 | 02:22 PM
YellowBacteria1's Avatar
Default B16 in EG swap help ( wiring )
I'm in the middle of swapping a B16 into my EG and need some input.
First, how can I tell if my car was ever originally V-Tec? I need to know so I know to run the vtec wires or not.
Is there an easy way to tell if my eg ( hatch ) was ever V-Tec? since it didn't have the original engine when I got it.
My B16 is JDM OBD0 B16a, I bought a brand new OBD1 distributor, and OBD1 ecu.
Does OBD1 wiring require a resistor pack? how can I bypass the resistor pack if I'm using high impedance injectors?
Old Jul 23, 2013 | 02:59 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: B16 in EG swap help ( wiring )
What model is the hatch? The VX and Si both had VTEC. Did your car have a previous engine in it? If so what engine? The DX/LX engine (D15B7) and the Si engine (D16Z6) both use 240cc injectors like the B16 so I'd use them and not the injectors that the OBD0 B16 came with.
Old Jul 23, 2013 | 03:02 PM
It didn't have an engine. the Harness on it was a vtec harness but I don't know if it was the actual harness.
I don't know what model it is. Where can I even check?
one person I know said it isn't vtec because it doesn't have a sun roof. is this correct?
Can't I just look to see if the wiring harness has the vtec wires?
where would they be located.
Also I have brand new 900cc high imp injectors i'm using. that's why I need to know about the resistor box
Old Jul 23, 2013 | 03:21 PM
JDMAF's Avatar
If it's a 92 it has the wires...
if not check the ecu plugs, if there is a wire in A4 you have the vtec wires... if you don't understand this then there is no reason for you to have 900cc injectors...
Old Jul 23, 2013 | 03:31 PM
I have 900cc injectors I'm turboing it.
it's a 94.
I'll check the A4. thanks that is what I was trying to figure out is where the Vtec wires are suppose to be on the ecu plug side.
Old Jul 23, 2013 | 03:39 PM
JDMAF's Avatar
All I'm trying to get at man is if you go to google.com and type in 92-95 civic pin out you wouldn't have had to make this thread... not trying to be a dick... google is your friend...
Old Jul 23, 2013 | 03:44 PM
if everyone just googled **** forums wouldn't exist.
Old Jul 23, 2013 | 04:07 PM
Technical Hero
Old Jul 23, 2013 | 04:09 PM
JDMAF's Avatar
PM Xctrac1 he's an expert on vtec wires...
Old Jul 23, 2013 | 04:12 PM
that guy is a douchebag no thanks.
88 EF Hatch
Engine Management and Tuning
Oct 7, 2009 07:50 AM
Logan76
Jan 23, 2009 08:14 PM
CHI-D16
Oct 19, 2008 07:54 PM
JDMEG688
Sep 21, 2006 10:08 AM
