Easy way to Remove Crank Bolt
Old Jul 25, 2013 | 07:37 AM
Danwelch's Avatar
Default Easy way to Remove Crank Bolt
I have seen a number of posts here about removing the crankshaft bolt on Civics. Most have recommended the special 2-part Honda tool - which is expensive. I saw a YouTube of a guy doing it with a chain and allen wrench and it works like a charm! You wrap the chain around the motor mount directly above the crank several times to secure it. Then loop the chain around the pulley (direction depends on whether you are loosening or tightening) and insert an allen wrench through a chain link and into one of the holes in the pulley. Now with a 17mm socket (or my 98 Civic) I can unscrew the bolt (with a big breaker bar!) and the chain/allen holds the pulley in place. Sweet!
Old Jul 25, 2013 | 07:37 PM
schneedrache's Avatar
Default Re: Easy way to Remove Crank Bolt
I had to heat mine up with map gas for over a minute and hit it with a 600ft/lb impact hammer. Not fun.
Old Jul 26, 2013 | 04:40 AM
stumpyf4's Avatar
Don't bother with holding the crank pulley tool, good 1/2" impact and air compressor. Work smarter not harder.
Old Jul 26, 2013 | 07:37 AM
rudebwoy's Avatar
jam a screw driver in the flywheel through the inspection hole, and loosen.
Old Jul 27, 2013 | 05:19 AM
94EG8's Avatar
Seagull Management
If it's a '98 civic there are no holes in the crank pulley. Some of the '92 - '95s do.
Old Jul 31, 2013 | 04:42 AM
krustofski_EM1's Avatar
like posted above lock the flywheel and use a power bar or use a good strong air gun with a big compressor.
if it doesnt go with either try heat it.
i had a mates car before and was fitting a n1 pulley. tried all options to open it and it wouldnt give at all.
got him to head into my work where we have a huge impact gun for taking off truck wheels and that worked a treat.
so if these options fail for you try a local tire place
bradley
13
Jan 9, 2012 02:12 PM
Fighterinsnatch
Jan 24, 2010 06:26 PM
WRXRacer111
23
Jan 20, 2006 02:36 PM
grngsr01
Oct 23, 2005 05:47 AM
yuckymucky
21
Mar 30, 2003 07:04 PM
