ctr cam ignition timing
Old Jul 15, 2013 | 08:55 AM
teamdarkside's Avatar
Icon6 ctr cam ignition timing
whats up guys here's my dilemma i have a turbo build b series
b16 head, brian crower springs, retainers,ferrara flat valves standard size
ctr cams with skunk 2 cam gears
gsr block , JE low compression pistons , eagle rods big bolt style
ect......
hondata tuned s300
car made good power after tune my question is my distributor is advanced all the way back no more adjustment can be made when i check timing with engine off all marks line up perfect, with engine on ignition timing is at 16* were i had it tuned at witch is perfect how can i get the distributor to be in the middle so i can adjust if i had to retard or advance the ignition timing ? (note i didn't use a dial indicator to see overlap on the cams when i did the timing)
thanks in advance for the help
Old Jul 15, 2013 | 11:12 AM
Default Re: ctr cam ignition timing
does anybody have a answer
Old Jul 16, 2013 | 05:48 AM
kyden's Avatar
why not just change the timing in your maps?
Old Jul 16, 2013 | 11:19 AM
that doesn't really answer my question
Treyschls
Apr 13, 2023 07:04 AM
johnwohl
Apr 1, 2008 07:29 PM
TranspeedMotorsports
Nov 12, 2006 09:11 AM
LSVTEC 91 Civic
Aug 31, 2004 06:35 PM
1SlowSi
May 2, 2004 02:57 AM
