s2000 failed smog High NOx
my s2k just failed smog and the tech said its 3x the max for nox and is a gross polluter.
This is in California
car is stock other than cold air intake
I know my cat is missing one of those spring bolts would that cause the NOx to be so high?
no check engine lights
just got the paperwork back
15 mph rpm 2018
Co2 9.91%
o2 5.53
HC Max 58- mine 25
CO Max .52 Mine .02
NO Max 451 mine 2221 Gross polluter 1936
25 mph rpm 2546
co2 10.30
o2 5.71
Hc Max 42- mine 18
CO max .50 mine .01
NO max 738 Mine 2129 gross polluter 1736
ive never had problems passing before would a cat start giving that much of problem in between testing?
also is an exhaust leak enough to cause such high numbers or just higher numbers like if i barely failed?
15 mph rpm 2018
Co2 9.91%
o2 5.53
HC Max 58- mine 25
CO Max .52 Mine .02
25 mph rpm 2546
co2 10.30
o2 5.71
Hc Max 42- mine 18
CO max .50 mine .01
ok so i hooked my car up to my obd2 scanner and looked at the live stream.
fuel trims
my ltft and stft are well into the negatives
-10 right now for the long term
and anywhere from -5 to -25 for short term
Map
intake map reading is around 11 inHg at idle
o2 sensors
bank 1 and 2 voltage around .6v to .95 v
bank 1 and 2 stf fluncuates from 6.5% to -25% and it cycles up and down consistantly like 1% a second and faster if holding a rev.
my car runs fine
i looked at my data stream not that long ago and everything was fine ltft was at 0%
fuel trims
Map
o2 sensors
my car runs fine
15 mph rpm 2018
Co2 9.91%
o2 5.53
HC Max 58- mine 25
CO Max .52 Mine .02
25 mph rpm 2546
co2 10.30
o2 5.71
Hc Max 42- mine 18
CO max .50 mine .01
15 mph rpm 2018
Co2 9.91%
o2 5.53
HC Max 58- mine 25
CO Max .52 Mine .02
25 mph rpm 2546
co2 10.30
o2 5.71
Hc Max 42- mine 18
CO max .50 mine .01
fuel trims
Map
o2 sensors
my car runs fine
fuel trims
Map
o2 sensors
my car runs fine
What are the trims at idle,cruise and WOT?
and the trims i posted were of idle. ill have to go out and drive it to get cruising and WOT ill post those in a bit
also do you think it matters that he put it as single exhaust when i have a duel exhaust?
WOW somethings really wrong, either with your car or his machine. No way your co2 should be that low and your O2 that high. Does your car run good?
(also you dont have a true dual exhaust, two cylinder heads are needed for that)
The exhaust leak killed your cat. It doesn't take long for this to happen as the oxygen sensor dumps enough fuel in there to melt your cat, imo.
This happened to me so I know from experience. My cat was killed in under 1000 miles.
so today i decided i would look at the cat and o2 sensors and take some pics. it didnt take long at all so ill put it back together and go drive it around and try to post those fuel trims at idle WOT and cruise.
here is the o2 sensor bank 1
this is the bank 2 o2 sensor the one that actually sits in the center of the catalytic converter
and my cat front and back of the honeycomb it looks okay to me but id like your take on it
Ok so put it all back together and replaced the spring bolt that has been missing cleaned the o2 sensors with brake cleaner And fired her up. At first I was like oh wow look she's all better because the short term fuel trims were at a steady -2 to +2 but as the car warmed up the fuel trims began to drop back to what they were before.
I also grabbed the trims at wot and cruise
At cruising they seem to even out to be normal -4 to +4 then at wot it just says 0%
Were you just theorizing when you mentioned an exhaust leak or do you actually have one ?
The first oxygen sensor looks like a ghost. Can't say I've ever seen one look like that.
Just a theory I can't imagine a missing bolt would throw my NOx numbers that far out of whack. There was def. no exhaust leak sound. But that theory is moot now that I replaced the bolt. As far as the o2 looking a bit pale I think it's a combo of it actually looking that way and the lighting
I feel like if the o2 was fighting an exhaust leak the trims would have been off a week aga as well. Compensating for what it thinks is lean by adding fuel. But they were normal a week ago. And now it thinks it's rich and leaning the trims out by subtracting fuel but I think it's a false rich because its leaning it so far out of whack that my NOx went skyrocketing up.
seafoam that thing and check for white smoking coming from the exhaust anywhere from the exhaust manifold to the precat oxygen sensor...paying special attention to the flange(or wherever you were missing the bolt originally)...if it seems fine just replace your precat oxygen sensor and do a "pretest smog" if it still fails clean out the egr..if it still fails I would replace the cat...would be my advice
Hi S,
You either had a pretty good exhaust leak or the emission machine's hose has a leak (going off of the 02 readings). By your post's it sounds like you didn't have that big of an exhaust leak.
The cat need's to get very hot to do it job and any leak is bad.
Your ltft is the one that you need to consider, the stft should move around like that.
Could be your precat O2 sensor is getting lazy as stated before.
thesmogman
thesmogman
What a big exhaust leak. Exhaust leak before the cat will cause high NOx reading. Make sure the front O2 is working properly and all the pulse air connection is still hooked up. You can check the O2 signal using a scan tool that does graphing. Run Chevron 91 as well. And is that an aftermarket high flow cat?
hmtcrxsir
23
Apr 20, 2017 11:27 PM
