Engine wont start after wire tuck
Old Jul 25, 2013 | 12:28 PM
DO-WORK-SON's Avatar
Default Engine wont start after wire tuck
97 civic EX just finished up my wire tuck and engine wont start, I've got a fuel pressure gauge on the fuel rail and even as the fuel pump is priming it shows zero pressure, so there's got to be something wrong there but i'm not getting how that could be? the only way i can even get the pump to prime is to disconnect the battery and then hook it back up again and then it will prime once but that's all it wont run again unless i repeat that process. I read something that if the engine doesn't sense oil pressure it will shut down the fuel pump could this be contributing to my problem?
Also on the instrument panel I've got a oil press light, SRS light (SRS has been removed) and Battery light that don't turn off even with the key completely off.
Old Jul 25, 2013 | 12:49 PM
Default Re: Engine wont start after wire tuck
Ok i jumper-ed the fuel pump and i got pressure, engine still wont start but at least i know its not the fuel pump now, what should i check now? i checked spark as best i could by myself and it is getting spark.
Old Jul 26, 2013 | 10:36 AM
So i trouble shot down to bad coil and ICM, waiting for parts now should be here tomorrow.
But i still cant figure out why i have dash lights that don't turn off with the key off, their not fully on, kinda dimmer until i turn the key then they are brighter. i know the SRS light will always remain on sense i removed it all but none of them should stay on with the key out.
Old Jul 26, 2013 | 11:23 AM
Just re-soldered main relay connections and now while the car cranks i can hear the relay making a constant clicking sound.
Old Jan 14, 2014 | 01:23 PM
MoiMotorsports's Avatar
call me 856 332 5450 u have 2 wires crosed green yellow and yellow black by the big conector by the brake booster
Old Jan 14, 2014 | 04:34 PM
VegasInvasion's Avatar
I'm Huge In Japan
Wire tucks should be illegal. I've seen three wire tucks done correctly in my entire life.
You're probably missing a ground somewhere, or you have a ground and power wire mixed up.
Honestly it could be any of them, you're going to have to go through them one by one. For future reference, never do a wire tuck.
Old Jan 16, 2014 | 02:16 AM
Runnerdown's Avatar
90% are not done correctly
Old Jan 19, 2014 | 08:32 PM
C_D0bs's Avatar
What's a wire tuck?
Old Jan 21, 2014 | 07:36 AM
rice a roni's Avatar
Need pics of wire tuck. But yes more than likely you're fucked. Just undo the wire tuck. Good luck.
Old Jan 23, 2014 | 10:49 AM
Charlie Moua's Avatar
like i've told people before, wire tucks are is not hard physicall work, it's just very detailed work. you can't just wing it.....
take your time, double check everything before you loom it up and secure it in place.
un-doing it is such as PITA.
92integracer
Aug 13, 2010 09:08 PM
blackbat11
Jan 27, 2008 07:11 PM
civicdx92
Jun 25, 2006 05:09 PM
ronqqq
May 30, 2005 09:39 AM
mrduque
Jun 12, 2002 09:44 PM
