can compression drop from engine sitting for long time?
Old Jul 12, 2013 | 09:30 PM
raverx3m's Avatar
Default can compression drop from engine sitting for long time?
I just did the compression in the gsr and it came up to 190 180 180 170
car sat for a year after accident and I don't know if the low numbers because of cold engine and sitting for long time or because it needs rings
Old Jul 12, 2013 | 11:48 PM
Orangevirus1's Avatar
Default Re: can compression drop from engine sitting for long time?
probably because the engine was dead cold and hadn't been heat cycled in a while.
on one of my engines I compression tested it after then engine sat for a few weeks and it was 30psi lower than hot.
Old Jul 14, 2013 | 06:20 PM
Trackrat#81's Avatar
Rings and cylinder walls might have gotten dry. Run it up to operating temp, then follow the comp check proceedure.
Old Jul 14, 2013 | 06:29 PM
raverx3m's Avatar
engine is out of the car cant run it up lol
Old Jul 15, 2013 | 06:11 AM
kyden's Avatar
compression tests are supposed to be done at operating temp.
JKing106
Sep 10, 2012 02:30 AM
range hadies
Mar 25, 2012 12:18 PM
jdmjoka
Mar 25, 2009 01:15 PM
honda_prelude_jay
Jan 3, 2009 03:36 PM
toooslow
Jun 26, 2003 05:35 PM
