o-ring groove on block
Old Aug 11, 2013 | 03:04 AM
vteczone's Avatar
Default o-ring groove on block
I have search but found nothing on HT. How far should the groove be from the cylinder bore?
Old Aug 11, 2013 | 04:59 AM
grumblemarc's Avatar
The Grumpiest
Default Re: o-ring groove on block
That's because it's not a DIY job nor a job for any shop that doesn't do them on a regular basis. And it will vary.
Old Aug 11, 2013 | 06:33 PM
vteczone's Avatar
Ok..so it vary depending on size of the bore? Im buying the isky groove o matic, so need some tips or recommendation on how far they should be. Its for b series block with 86mm bore. Never had pistons over 85.5mm and I heard about issue of leaking with 86mm or larger. Any info will be useful.
hizler07
Sep 14, 2007 03:21 PM
sinister357
May 19, 2005 06:42 PM
myDC4rox
Jan 17, 2005 10:35 PM
