leaking compression from cyl 2 to cyl 1??
Old Aug 19, 2013 | 08:24 PM
wayneDOHC's Avatar
Default leaking compression from cyl 2 to cyl 1??
ok I have 98 teggy gsr, when i got it it was running a little rough. is sounds like a Subaru. so i did the timing (which was off a little, cams weren't aligned right), and adjusted the valve lash but still found the engine loosing compression in cyl 2 only. the car doesn't loose and coolant or oil or burn oil. i did a wet compression also, rueling out bad rings. so i set cyl 2 to tdc and put compressed air in the cyl and i could hear it blowing out pretty steady somewhere. the sound lead my ear over cyl 1 spark plug tube, where i could physically feel it blowing on my ear. i put my hand over it and it surely was leaking from cyl1. what does this mean? i thought head gasket but im loosing coolant. and also, cyl 1 does not leak compression.
Old Aug 20, 2013 | 02:44 AM
grumblemarc's Avatar
The Grumpiest
Default Re: leaking compression from cyl 2 to cyl 1??
Noob. Stop spamming asking the same question over and over starting new threads while you go. You posted this a week ago in the Integra forums and never bothered to go back and respond to the people attempting to help you.
https://honda-tech.com/forums/acura-integra-6/leaking-compression-cyl-2-cyl-1-a-3163999/
Old Aug 20, 2013 | 11:58 AM
wayneDOHC's Avatar
yeah im new to Honda tech and find the forum a bit confusing. but thankyou for sharing the link to the post that got moved to acura integra, I was previously unaware it got any replies. now I have the answers I need, so I appreciate it. don't gotta be a dick tho lol
96civicdx2o3
26
Mar 5, 2013 07:18 PM
vipokc
Feb 4, 2009 06:57 AM
huge230
Dec 18, 2006 07:29 AM
Ri5e
Feb 10, 2002 09:54 AM
