Igniter keeps burning after a month. Why? help please
Old Aug 13, 2013 | 02:51 PM
boostedsihatch's Avatar
Default Igniter keeps burning after a month. Why? help please
This is the second time I replaced the distributor because of the ignitor burning out, but would like to know how to prevent this from happening again. First time it went bad was when I was on the road. Second time it went bad was when i was at home uploading my hondata settings.
How can i figure out why the igniter keeps burning out?
Is there aftermarket solution?
Only thing I was able to find is that it may be the wire harness.
Suggestions?
Setup:
95 civic
Turbo lsvtec
Stock distributor
Old Aug 13, 2013 | 03:37 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: Igniter keeps burning after a month. Why? help please
What type of igniters are you using? OEM, aftermarket?
Old Aug 13, 2013 | 03:43 PM
Oem
Old Aug 13, 2013 | 03:45 PM
I just replace the whole distributor by buying it from somebody on here since cheaper than just buying the ignitor from Honda
Old Aug 14, 2013 | 01:36 AM
Technical Hero
Check all the wiring going to it. Also how is the rest of your ignition system? Wires, plugs? Heat is usually the main factor in reducing the life of an igniter. Excess resistance from bad plugs and wires can cause the coil to heat up and cause premature failure.
Old Aug 14, 2013 | 02:37 PM
Ill have to inspect all the wires tomorrow.
I have ngk braided wires with ngk6282 spark plugs. I have to test these parts with a multi-meter to see if their within spec.
The coil works fine, but ill check to see if its in spec as well
How do I know if igniter is getting too much heat?
Thanks for your help.
Old Aug 26, 2013 | 05:17 AM
So I guess its something else that caused my car not to spark because I swapped in my the previous distributor back in (the one that I thought the igniter went bad on after testing specs) and the car cranked right up. Only thing changed is the rotor.
Old Aug 26, 2013 | 06:03 AM
yungmulacrx's Avatar
Be careful i have a couple igniters that work great for 15 min then drop dead..
Old Aug 26, 2013 | 08:55 AM
Will do. I been using it for several days now. Hasnt failed yet. I do have a backup distributor that I purchased from fracas on here as back up and a distributor housing from Blown90hatcH with another igniter as back up as well.
97Prelude17
Sep 25, 2012 06:43 AM
drtile
Jan 2, 2008 03:17 PM
MugenHonda
Oct 2, 2005 01:28 PM
gsrvx
Jun 6, 2002 11:27 AM
