What valve stem seal to use with oversized valves?
I have some oil burning issues. Leak test is good and compression is good as well. All i can think of is the valve stem seals.
When the engine was built I remember I used OEM valve stem seals and the valves were CROWER oversized. They were the .5mm oversized. Could this be the care of my oil burning issue because Im using the wrong valve stem seals? What valve stem seals should I use of that is the case? Thanks
Atomic1
03-27-2010 08:57 PM
E46M3CB
03-08-2004 08:54 AM
