Does anyone know how to kill the Check Engine Light?
Old Feb 7, 2005 | 05:57 AM
everlasting1832's Avatar
Default Does anyone know how to kill the Check Engine Light?
I know the problem with the check engine light. I did a scan and it came up with somethlng to do with the catalic converter. I have a stock cat in there with a full exhaust setup. Im thinkiing if i replace the cat it the light still might be on there. then i would have to replace the oxygen sensor. screw that I want to kill that light, does anyone know which wire to cut? Oh and also my car was built in california. its a 99-00 si
Old Feb 7, 2005 | 06:52 AM
PrettyLude's Avatar
what other mods do you have? what exactly is the code for? running too rich? or cat below threshold? or o2 sensors?
Old Feb 7, 2005 | 08:27 AM
civic-4-ges's Avatar
Default Re: (PrettyLude)
120 volts will kill it or a pellet gun...
If you want to get rid of it, I am sure you can trouble shoot it!
Old Feb 7, 2005 | 09:33 AM
FalkenSiR's Avatar
Default Re: (civic-4-ges)
sim
Old Feb 8, 2005 | 04:58 PM
The code came up with the Catalic Below Threshold.........any suggestions? would i have to replace my catalic converter or is it something else? thanks
Old Feb 8, 2005 | 06:04 PM
Reservation-Sensation's Avatar
fukk it take out the damn bulb for the "check engine light, i did it works like a ****** champ
Old Feb 8, 2005 | 09:20 PM
Red Andy's Avatar
Default Re: Does anyone know how to kill the Check Engine Light? (everlasting1832)
Perhaps a o2 simulator would work if the engine light is on because of the secondary oxigen sensor. If you take the bulb out, your still in limp mode which your car won't run as efficient as it should.
Old Feb 8, 2005 | 09:32 PM
PrettyLude's Avatar
the sim will the work just fine to get rid of that check light
Old Feb 8, 2005 | 11:10 PM
ek9poorR's Avatar
Default Re: (Reservation-Sensation)
get a gal. of gas pour it all over the dash and light it up...it should kill the check engine light
Old Feb 9, 2005 | 12:11 AM
gassaversracing's Avatar
Default Re: (ek9poorR)
i didnt read any of what people posted. who cares? i got the solution to any car problem. 5 gallons of gas and a flaming arrow. why not a match? you'd be too close to not get hurt. advice from a drunken man. haven't tried it before, but safety first my honda brother.
Old Feb 9, 2005 | 07:07 AM
h2392si's Avatar
Default Re: (gassaversracing)
its time to replace the cat buddy. i had the same code and I replaced mine with a high flow magnaflow cat and it took care of the light. Your si wont run properly without it and it kills you gas milage,just replace the cat.
Old Feb 9, 2005 | 08:37 PM
PrettyLude's Avatar
Default Re: (h2392si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2392si &raquo;</TD></TR><TR><TD CLASS="quote">its time to replace the cat buddy. i had the same code and I replaced mine with a high flow magnaflow cat and it took care of the light. Your si wont run properly without it and it kills you gas milage,just replace the cat. </TD></TR></TABLE>
you don't have to replace the cat, i had the same exact problem and the o2 sim cured the check light
Old Feb 9, 2005 | 08:40 PM
What exactly is an o2 simulator??? explain please..thanks!
Old Feb 10, 2005 | 06:30 AM
PrettyLude's Avatar
it fools the ecu into thinking that everything is ok
try and get a casper's electronics one, its plug and play, no cutting at all
Old Feb 10, 2005 | 11:23 AM
o2 SIMULATOR HERE I COME!!!!!! I never thought they would have something like this..but it all makes sense now!!! hoooo hoooo..thanks everyone for da help!!! now pay me 80 kajillion dollars so i could buy some Rota C10's!!!!
fcardenas
Honda Civic (2001 - 2005)
Mar 16, 2018 12:56 PM
Nitto
Aug 10, 2004 07:11 PM
GSR-Civic
10
May 31, 2004 10:10 AM
nexus da9
Mar 2, 2004 03:36 PM
Komsomol
Dec 27, 2002 09:20 AM
