Lower Radiator Hose Question
Old Feb 2, 2005 | 07:46 PM
Dumped DB2's Avatar
Default Lower Radiator Hose Question
Hey guys. I have a 1992 integra with a b18a1(Stock) and a few days after christmas, my car over heated a few times and was acting strange. So I replaced the thermostat and that didn't work. So I figured I the radiator was clogged so I replaced the radiator and upper and lower hoses and that really didn't work. So then I changed the water pump and timing belt and had a valve adjustment done. Its not over heating, but I noticed that my lower radiator hose is cold unlike the top one which is hot? What seems to be going on here? any help would be very much appreciated!
Old Feb 2, 2005 | 07:57 PM
Slow ass EF's Avatar
Default Re: Lower Radiator Hose Question (Pjct2ndGenTeg)
ur fine i wouldnt worry
Old Feb 3, 2005 | 04:56 AM
NJIN BUILDR's Avatar
The top hose is the hot water leaving the engine.The lower hose is the cooled water returning to the engine.When they're both hot you have a problem.
Glenn
Old Feb 3, 2005 | 07:53 AM
Dumped DB2's Avatar
Default Re: Lower Radiator Hose Question (NJIN BUILDR)
i hope so i just thought both were always suppose to be hot
Old Feb 3, 2005 | 10:57 AM
Dumped DB2's Avatar
anyone else have any imput
Old Feb 3, 2005 | 01:38 PM
Dumped DB2's Avatar
anyone?
Old Feb 3, 2005 | 02:43 PM
msmotorsports's Avatar
Once the motor is up to operating temps both hoses will be hot. If the bottom hose is still cold then you have a clog in either the radiator or block.
Old Feb 3, 2005 | 02:59 PM
Dumped DB2's Avatar
Default Re: Lower Radiator Hose Question (msmotorsports)
how would i go about un clogging the radiator? try the bolt on my head right next to the header?
Old Feb 3, 2005 | 03:02 PM
my car has never had a problem and my lower hose doesnt get hot at all....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">The top hose is the hot water leaving the engine.The lower hose is the cooled water returning to the engine.When they're both hot you have a problem.
Glenn</TD></TR></TABLE>
Old Feb 3, 2005 | 03:04 PM
Dumped DB2's Avatar
Default Re: Lower Radiator Hose Question (LSVTECJay)
im confused as hell now
Old Feb 3, 2005 | 05:47 PM
What do you mean it stays cool. It has to get warm or your car will be run too cool. Most motors run best when coolant temps are around 180 to 200 Degrees.
Old Feb 8, 2005 | 05:05 PM
ekek888's Avatar
the top should be warmer than bottom. temp is about 180F when warmed up. if its not this temp , hot or colder, some thing is wrong. check thermostat.
Old Feb 8, 2005 | 05:53 PM
SOHCD16y8's Avatar
Default Re: Lower Radiator Hose Question (ekek888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pjct2ndGenTeg &raquo;</TD></TR><TR><TD CLASS="quote">how would i go about un clogging the radiator? try the bolt on my head right next to the header?</TD></TR></TABLE>
if the hoses are the right temp and your not overheating anymore why do you think it is clogged?
92eg_h22
Aug 2, 2008 11:51 AM
fanta!
Aug 14, 2005 02:14 PM
Import Tuna
May 19, 2004 05:12 PM
RTW DC2R
Dec 16, 2003 09:20 PM
