sleeving or what else should i do to my engine?
hey i have a 93 turbo del sol running 10 lbs of boost on a 98 civic motor (JDM D16Z6) and i want to start increasing my amount of boost. what type of pistons should i get that are reliable but affordable (inexpensive) and what should i so about sleeving the motor (what type of sleeves and how long will it take and so forth...)
Thanks
eric
Thanks
eric
I wouldent get sleeves unless your gonna ge everything built bottomend wise at least just balance it with rod/piston
You can always add some good Arias pistons, Golden Eagle Mfg. HD sleeves and some Eagle rods. That is a good combo for your set-up. Eagle rods are Fairly inexpensive, we have a deal on Arias pistons when you get your block sleeved by Golden Eagle. Give us a call (909) 592 - 4311 ext. 104
Boost_jnky
Apr 29, 2005 04:41 PM
USDM 4G VTEC
Jan 28, 2004 09:28 AM
