Distributor Problem?
Old Feb 5, 2005 | 04:26 PM
usdmcivic94's Avatar
Default Distributor Problem?
Problem is i have a code 9 and i want to measure the resistance of the dizzy but i dont know what terminals to ohlm out.
obd1 b16a
95 civic
Old Feb 5, 2005 | 05:28 PM
Default Re: Distributor Problem? (usdmcivic94)
bump
Old Feb 5, 2005 | 09:29 PM
Lord Helmet's Avatar
got a helm manual yet? that should point you to the right direction.
Old Feb 7, 2005 | 05:01 AM
Anyone else.
Old Feb 10, 2005 | 07:48 AM
i would just like someone to scan me a page with what terminals to ohlm out. thank you
Old Feb 10, 2005 | 08:06 AM
JimBlake's Avatar
Code 9 would be the CYP sensor in the distributor. On my '95 its the orange wire (shielded) & the white wire. You can look for broken/loose wires all the way back to the ECU. Or you can take off the distributor cap & look for broken stuff in there.
But it's more than just measuring resistance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv &raquo;</TD></TR><TR><TD CLASS="quote">got a helm manual yet? that should point you to the right direction.</TD></TR></TABLE>
Old Feb 10, 2005 | 09:55 AM
Default Re: Distributor Problem? (JimBlake)
OFL from orange to white
Old Feb 10, 2005 | 10:42 AM
JimBlake's Avatar
IF you mean open-circuit, then get inside the distributor & look for a broken wire going to that sensor itself. I don't have the book with me, but it should probably be a measureable resistance, not open.
If the sensor itself is bad, I believe you can't buy it separate from the distributor?
Old Feb 11, 2005 | 04:17 AM
EE_Chris's Avatar
If that particular sensor is bad, the entire distributor sub-assembly has to be replaced - you can swap over all the other internals though.
Old Feb 11, 2005 | 04:46 AM
PrettyLude's Avatar
they won't sell just that sensor JimBlake
Old Feb 11, 2005 | 03:26 PM
Default Re: Distributor Problem? (EE_Chris)
I dont think it is the distributor because the cel light comes on when the car warms up in the beginning of the day and later i go out maybe three or four hours later turn the car on and the engine is still cold but the cel pops up right away. i think it might be the senor wire to to ecu.
Old Feb 11, 2005 | 04:04 PM
blkturborex's Avatar
i have the same problem, with a obd 0 b16, i just bought a new distributer and its happening again.
Old Feb 11, 2005 | 05:38 PM
Anyone else ever had this problem?
Old Feb 12, 2005 | 03:37 AM
EE_Chris's Avatar
Well...here is kind of a long shot:
I've seen on more than a few occasions that distributors from AutoZone and the like tend to be 'bad' in some respect - whether it be a weak coil or igniter, just something.
I also know that when the bushing in the distributor begins to wear, it allows the shaft to vibrate and since the sensor wheels are mounted on this shaft, their signals begin to 'vibrate' as well - the ECU can't really make heads or tails of it, so a code pops up.
Now, I don't know whether your unit is a stock with a lot of miles or a 'new' unit from AutoZone - but since you say the code only pops up when its cold - perhaps the bushing shrinks enough from the cold which allows the shaft to vibrate but then warms up, expands back, and now no vibration.
Have you taken the distributor cap off - is there any red dust in there?
Old Feb 12, 2005 | 10:14 AM
the light doesnt come on until the car has warmed up a little in the beginning of the day. after that it comes on everytime i turn the car on.
Old Feb 12, 2005 | 03:21 PM
the same thing happens to me and the first time this happened i had had the wire dust so i knew it was shot but it is happening and there is no broken wire dust and after the code comes on car runs like ****, but if i reset the ecu it wont see it for a while and the car will run great untill like a day later when the code come back and car starts to bogg and choke on acceleration like its not running on all cylnders
Old Feb 12, 2005 | 03:23 PM
and i used to run 17deg advanced timing but to see if that was causing it i run 15 deg. and it still happens
Old Feb 13, 2005 | 04:18 PM
also when at an idle my tach that is wired to my distributer, the needle jumps all over it happens when driving too please help
Old Feb 13, 2005 | 05:57 PM
PrettyLude's Avatar
bouncy tach= bad ignitor
Old Feb 13, 2005 | 08:01 PM
Default Re: (PrettyLude)
My tach doesn't bounce and also have hesitation sometimes
Old Feb 14, 2005 | 06:34 AM
jdmep3ctr's Avatar
Are B-Series Distributors interchangeable?
Old Feb 14, 2005 | 07:39 AM
PrettyLude's Avatar
the vtec ones are, not the non vtec
Old Mar 11, 2005 | 10:15 PM
It was the CYL Position sensor.
pspryu101
27
Dec 12, 2010 11:14 PM
the.hamburglar
Jul 29, 2004 05:42 AM
d_jarrell
Jul 22, 2004 10:26 AM
CivicHatchback14
Jul 14, 2004 12:00 PM
