00 civic si check engine code 3 obd2
Old Feb 4, 2005 | 11:35 PM
SIckcivic00's Avatar
Default 00 civic si check engine code 3 obd2
i just put in a turbonetics hybrid t3/4 on my 00 si, runns great untill the check enine light comes on and goes into protect mode. i looked up the code it says map sensor. so i bought a missing link to fix the problem, it did not fix it, the code comes on again, mostly after the engine get up to norm temp. . if i drive even in boost its ok untill it gets hot. if i drive at normal it comes on with no boost, mostly when i let off the gas. Is the odb1 code and the obd2 code the same? i do not think so. i have the obd2. please tell me what other problems would cause this. after this i will be golden. i have the VAFC2 with stock injectors. thanks for all and any help. MY email is MILESBIZZELL@YAHOO.COM
Old Feb 5, 2005 | 12:39 AM
PrettyLude's Avatar
did you put the missing link in the right way?
Old Feb 5, 2005 | 01:01 AM
Default Re: (PrettyLude)
yes i put it in right after i got it from a freind. why?
Old Feb 5, 2005 | 01:31 AM
Default Re: (SIckcivic00)
also should i go OBD1?
Old Feb 5, 2005 | 03:25 AM
havok hybrid's Avatar
DID you install the missing link the right way .... ??? ...
Old Feb 5, 2005 | 02:29 PM
PrettyLude's Avatar
you shouldn't be getting a map code if its installed the right way, try turning it around the other way and see if that helps
Old Feb 5, 2005 | 09:12 PM
ok thanks i never thought of that, i talk to a guy who owns a turbo shop, he says there is 3 types of missing links. the one i have is an older one and it does not have the hole on the side of it that has the filter. that may be my problem too. but 2morrow i turn around the link, thansk for your help. i am so close.. it makes me want to cry.. miles
rogha
May 4, 2010 08:50 AM
Skadaloz
Jul 28, 2009 05:48 PM
black_99SI
Dec 7, 2007 05:14 AM
highboostb18c1
Mar 28, 2005 09:06 AM
SIckcivic00
Feb 5, 2005 05:55 AM
