Soldering or Butt Connector?
Old Feb 8, 2005 | 02:58 PM
1SlowSi's Avatar
Default Soldering or Butt Connector?
im wiring up the injectors and map sensor and used butt connectors cause i suck at soldering. Will this be okay? I know it has a solid connection.
Old Feb 8, 2005 | 03:47 PM
fknslmd's Avatar
Default Re: Soldering or Butt Connector? (1SlowSi)
since your wiring up such important parts like that i would solder them. just practice a little, you should pick it up quick
Old Feb 8, 2005 | 04:58 PM
PrettyLude's Avatar
Default Re: Soldering or Butt Connector? (fknslmd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fknslmd &raquo;</TD></TR><TR><TD CLASS="quote">since your wiring up such important parts like that i would solder them. just practice a little, you should pick it up quick</TD></TR></TABLE>
Old Feb 8, 2005 | 05:20 PM
Pootie's Avatar
Default Re: Soldering or Butt Connector? (PrettyLude)
Soldering is not the best way connect wires on something that vibrates, such as an engine harness. It's great if you have something like a circuit board that stays stationary. But when you solder two wires together, the point where it transistions from bare wire to solder becomes a stress riser. You thus have a good chance of the wire breaking at this point. I suggest using a quality butt connector on anything that moves.
Old Feb 8, 2005 | 05:44 PM
SOHCD16y8's Avatar
butt connector with heat shrink wrap over it
Old Feb 8, 2005 | 09:04 PM
Mid Life Kool-Aid's Avatar
Default Re: (SOHCD16y8)
solder and shrink wrap. its not hard at all and I'm sure if you paid anyone to do it, it wouldn't be much more than a case of beer. ive never seen or heard of a soldered wire breaking apart from vibration unless it was under stress.
Old Feb 9, 2005 | 07:19 AM
Wes V's Avatar
Default Re: (Mid Life Kool-Aid)
Dang; learn how to solder! We are not talking about a major investment in tools. There is NO reason to not know how.
I use "nude" butt splices, solder them after crimping, and then cover that with heat shrink tubing. By doing this, I know that an electrical gremlin will not come back to get me in a years time.
Wes
Mikey3000
Jul 13, 2008 07:57 AM
92EG8
23
Nov 5, 2006 01:17 PM
IGGY
Oct 10, 2006 09:46 AM
rotasol
Jul 23, 2006 10:52 AM
thinkbrianthink
Mar 6, 2003 08:52 AM
