octane help
Old Feb 8, 2005 | 04:59 PM
Kutsuju_TurboCivic's Avatar
Default octane help
Ok a little info. I have a 2002 civic boosted. Due to the shitty design of the new civics you cant retard the ingnition timing. It is all electronic controlled with individual coil packs. That said. I was running 100 octane in germany and running 13psi no problems. Here in Cali only thing I can find at the pump is 91. What do you suggest I do to be able to run 91 octane reliably. I ahve tried retarding the cam and it did not fix the problem. Also the fuel pressure reg. is in the tank due to being a returnless fuel system. any help would be great. Should I add fuel and run rich just to keep from detonating or missfiring?. I have 2 extra injectors with a stand alone computer for them so I can adjust the fuel and way I want. thanks
Old Feb 9, 2005 | 05:57 AM
JimBlake's Avatar
Default Re: octane help (Kutsuju_TurboCivic)
First make sure you know what octane... Most of Europe labels the pumps with RON, but USA uses (RON+MON)/2. So that german 100 might not be much (any?) better than our 92 or 93. You might not be as far off as you think.
Old Feb 9, 2005 | 04:03 PM
Default Re: octane help (JimBlake)
well I thought about that but tha car runs like ****. can't even get over 2psi without misfiring and stuttering. It detonates too. I tried retarding the cam but it didn't help. I tried running really rich but no help either. I am out of ideas.
Old Feb 10, 2005 | 03:39 AM
JimBlake's Avatar
Strange... That sounds too severe to be caused by a couple points of octane rating. Check to see whether you've got something else going on.
CA121
Jul 6, 2011 09:34 PM
ToryluvshisDA
May 6, 2008 04:46 PM
projekt-sol
Dec 18, 2007 06:56 PM
AZprelude
Feb 13, 2007 08:03 PM
H22A_pOwer
Nov 5, 2002 12:22 PM
