Axle loose in transmission
Old Jun 12, 2006 | 02:30 PM
powerofdreams8's Avatar
Default Axle loose in transmission
92 VX; LSVTEC w/ hydro b16 transmission. Axles are thought to be 90-03 integ on the passenger side. Car has been on these axles for over 15,000 miles; the other day the pass. axle just pops out. Put new axle in and I found that the axle is loose in the tranny even after everything is bolted back down, fluid is leaking from where the axle enters the transmission. Please tell me I don't need a new tranny.
Old Jun 12, 2006 | 03:24 PM
Default Re: Axle loose in transmission (powerofdreams8)
quick update, reinstalled original axle and the car kicked it out as soon as I put it in gear after starting the engine. Axle was definately seated fully in tranny. We also installed a new c-clip on the axle before re-install.
Old Jun 12, 2006 | 04:30 PM
Bense's Avatar
you need to use 94-01 integra axles. or 99-00 civic si axles.
Old Jun 12, 2006 | 06:38 PM
Default Re: Axle loose in transmission (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">you need to use 94-01 integra axles. or 99-00 civic si axles.</TD></TR></TABLE>
Ok, thanks; but why has this axle been fine for over 15,000 miles of hard driving and all of a sudden it pops out of the tranny repeatedly even after changing to a new c-clip?
Old Jun 12, 2006 | 06:47 PM
Bense's Avatar
hm, that's odd.
Old Jun 13, 2006 | 07:30 AM
diff gears look fine inside, not stripped or anything unusual that I see.
freshvibes
Nov 23, 2007 07:54 AM
nonvteclude
Aug 7, 2006 08:45 PM
NstyGrnHatch
10
Feb 15, 2005 11:35 AM
crxgsr91
Oct 22, 2004 02:51 PM
NikoZai
Jul 28, 2002 09:21 PM
