recently purchased 93 si
i recently purchased a 93 si. though it runs great the shifter seems to be really loose even when it's in gear. when it's in gear i can still move the shifter around like when it's in neutral. is that a sign of a bad tranny? please help. thanks.
Bushings. There is one at the very bottom of the shifter to the linkage, and another where the shifter is held to the chassis. I think it's the one for the chassis. Unfortunately you have to go under the car to get to it.
But it is pretty easy once you get in there,
To Check it. Grab the whole shifter rod. Support the top with your one hand, then take your other hand on the bottom most part you can get to move back and forth and see how much play is in the bottom of the shifter.
Good luck!
Good luck!
