HELP transmission will not slide back on....
Old Jun 7, 2006 | 12:07 PM
k4ff1n3's Avatar
Default HELP transmission will not slide back on....
ok i have a b20 and im putting my itr trans on . ive done 1 transmission swap and everything went smooth , but this time i get the trans about an inch from being on and it just stops... any suggestions... please help as i am doing this today.
Old Jun 7, 2006 | 12:20 PM
Crazydave's Avatar
Default Re: HELP transmission will not slide back on.... (k4ff1n3)
is it on the dowls, or does it not even get to that point.
double check that your clutch alignment
sometimes, once it's on the splines, you need to start the bellhousing bolts and slowly crank in the tranny bolts in a star pattern.
Old Jun 7, 2006 | 12:29 PM
k4ff1n3's Avatar
Default Re: HELP transmission will not slide back on.... (Crazydave)
yeah i used a clutch alignment tool so im not sure that thats the problem...
and no it dosent even get to the dowels
the half shaft is on the splines, but i cant see if the actual trans splines are getting on to the clutch.
Old Jun 7, 2006 | 02:19 PM
User 5426's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k4ff1n3 &raquo;</TD></TR><TR><TD CLASS="quote">yeah i used a clutch alignment tool so im not sure that thats the problem...
the half shaft is on the splines, but i cant see if the actual trans splines are getting on to the clutch.</TD></TR></TABLE>
Clutch alignment, trust me. I did it the first time without the tool. The second time it too me 5 hours and I still didn't succeed without buying a whole clutch kit so I could use it's alignment tool.
Even with the alignment tool it still can be a little off.
Old Jun 7, 2006 | 02:42 PM
k4ff1n3's Avatar
Default Re: HELP transmission will not slide back on.... (EsQueue)
yeah i noticed that the alignment tool was still slightly loose..... i guess ill be out there all night messing with it till it slides on....
thanks for the help guys!
Old Jun 7, 2006 | 02:43 PM
Crazydave's Avatar
check the input shaft to the flywheel pilot bearing... (even though I don't think it's getting that far in)
Some times you have to wiggle it
also double check that the clutch splines fit on the input shaft, and can move down the shaft
try reassembling the clutch/flywheel/ clutch alignment tool.
maybe it moved and it's off.....
Old Jun 8, 2006 | 08:01 AM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
make sure the shaft can fit into the pilot bearing. I had a problem puttin in a tranny once. Figured out that the shaft didnt want to go into the pilot bearing. almost threw a pipe into the windshield
Old Jun 8, 2006 | 11:27 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (phyz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phyz &raquo;</TD></TR><TR><TD CLASS="quote">make sure the shaft can fit into the pilot bearing. I had a problem puttin in a tranny once. Figured out that the shaft didnt want to go into the pilot bearing. almost threw a pipe into the windshield</TD></TR></TABLE>
ITR Transmissons have a bigger shaft than some other b-series transmssions. Make sure the pilot bearing is the right size.
Old Jun 9, 2006 | 04:40 PM
k4ff1n3's Avatar
Default Re: (JDM_Ej)
for those interested the LS pilot bearing fit perfectly and the trans is back on..... it was the damn clutch ....i hate cheap alignment tools
Old Jun 10, 2006 | 01:49 PM
User 5426's Avatar
Default Re: (k4ff1n3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k4ff1n3 &raquo;</TD></TR><TR><TD CLASS="quote">for those interested the LS pilot bearing fit perfectly and the trans is back on..... it was the damn clutch ....i hate cheap alignment tools </TD></TR></TABLE>
Just as I was saying.
jbrokos307
Mid-Atlantic (Sales)
Nov 2, 2009 07:43 AM
civicsi18
Transmission & Drivetrain
Aug 16, 2008 08:11 AM
94xGSRxINTEGRA
10
May 17, 2007 03:19 PM
civdub21
May 11, 2007 12:16 PM
Dom-
Apr 22, 2004 10:12 PM
