is this enough
Old Jun 15, 2006 | 10:07 AM
turbozcteg's Avatar
Default is this enough
i recently put a mildy built b18 into my ef and now it wont start, it was converted over to multipoint from dpfi and everything was soldered and heat shrinked and then wraped
im getting fuel, i have comp. i have my timing set right, but with the spark i have some but i dont think its enuf
when i set the plug and wire on my head i get little faint sparks, when i put it to the core support i get big sparks and huge snaps
and last night i got the **** shocked out of me lol
but my main question then is do i need better grounds
i was told to add another ground cause its not grounded enuf
i have the main neg. batt cable one to the tranny
and then one from the rad. support to the valvecover stud
do i need more
any help is much appreciated
~jake
Old Jun 16, 2006 | 06:21 PM
turbozcteg's Avatar
Default Re: is this enough (turbozcteg)
bump anyone
Old Jun 16, 2006 | 08:43 PM
bigsubs's Avatar
are you trippin any check engine lights? Also did you check the ignition control module?
Old Jun 17, 2006 | 01:32 PM
turbozcteg's Avatar
Default Re: (bigsubs)
no, no codes
the light comes on tho and ive had the ecu tested so it works
but i cant figuer out this crap
there is the icm located ???
El Boricua
Apr 7, 2008 04:13 PM
yoursupahero09
10
Jan 23, 2007 04:19 AM
del_barry
45
Apr 7, 2006 05:07 PM
Skip
10
Jan 29, 2004 07:42 PM
2k1_ITR_0736
Jan 27, 2003 06:01 PM
