Helicoil removal extraction?
Old Jun 7, 2006 | 07:18 PM
Muckman's Avatar
Moderator in Chief
Default Helicoil removal extraction?
Its a very long story but in short the tang at the bottom didnt break off clean and when the bolt was screwed in the helicoil was dragged deeper in the hole which wasnt fully tapped so it was pushed inward which made the problem worse. Basically its all expletiveed up now. Is there a way to remove a helicoil?
Old Jun 7, 2006 | 07:20 PM
Muckman's Avatar
Moderator in Chief
Default Re: Helicoil removal extraction? (Muckman)
I cant get at it with picks or needle nose pliers. Ive even tried loctite'ing a bolt in there, hoping the coil would come out with the bolt.
Old Jun 7, 2006 | 09:18 PM
Jim Truett's Avatar
A very thin coat of JB Weld on the threads of a bolt would probably be more effective.
Old Jun 8, 2006 | 06:17 AM
Muckman's Avatar
Moderator in Chief
Default Re: Helicoil removal extraction? (Jim Truett)
I dont think it can hold the shearing force.
Old Jun 8, 2006 | 01:58 PM
non-VTEC's Avatar
hmmm......i think you may be **** out of luck.......unless you drill it the next size over and intall a oversized heli-coil and oversized bolt......
Old Jun 8, 2006 | 03:17 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">I dont think it can hold the shearing force.</TD></TR></TABLE>
The 2 part epoxy will be much stronger than the Cyanoacrylate based Loctite you tried before.
Old Jun 8, 2006 | 03:21 PM
Muckman's Avatar
Moderator in Chief
Ill give it a shot as its my only option right now. Thx
Old Jun 8, 2006 | 04:42 PM
JimBlake's Avatar
I think you should use a very thin amount on the bolt. You don't want any excess to ooze around & glue the coil into the hole.
EFstyle
23
Jan 27, 2007 10:49 PM
DC4GB
Oct 12, 2006 10:25 PM
civicEXtreme
Suspension & Brakes
Feb 22, 2006 02:36 PM
Carnage R1
Apr 26, 2005 11:12 AM
Layziebtnh055
May 14, 2004 06:42 AM
